Hi all,
simple Problem:
3 Screen Setup. The Pinballx Table Overview don´t Show the DMD on my dmdmontior. It is a black field instead the dmd Video.
The DMD Video is correctly installed via the Gamemanger. If I start the table, the Pimmamedmd was shown corrrectly.
Any Ideas?
Hi, Welcome to the Forums! First idea, please provide us with copies of your pinballx.ini and log.txt (Click here for additional information on how to find these files and others that may be required). Likely you do not have something properly enabled, but we can't be sure without copies of these files. Thanks!
The first thing I will recommend is downloading and installing the latest version 1.98. You are at 1.95 and there have been some significant fixes applied since your version. You may need to submit a new log.txt file if the issue persists after upgrading.
Here they are.... unfortunately same problem with lastest Version.
two from my tables shown a (non real) dmd Image. All Images imported by game Manager.
[Display]
Monitor=0
rotate=270
Windowed=False
WindowWidth=480
WindowHeight=720
WindowX=0
WindowY=65
PlayFieldBrightness=230
WheelTextColor=ffffffff
InfoTextColor=ffffffff
InfoTextOutlineColor=ff000000
FilterTextColor=ffffffff
MenuColor=ffffa500
[BackGlass]
monitor=2
x=0
y=0
width=1920
height=1080
[DMD]
monitor=1
x=0
y=200
width=1024
height=350
AutoPositionPinMAME=True
UsePinMAME=False
HidePinMAME=False
[FileSystem]
EnableFileMatching=True
[Interface]
DesktopModeEnabled=False
EnableAdditionalDetail=False
ShowSystem=False
ShowRatings=False
[Audio]
StreamVolume=70
SampleVolume=50
PlaySoundInVideos=True
[Startup]
playsound=True
playvideo=False
StartWithWindows=No
[KeyCodes]
quit=27
left=37
right=39
select=13
rotate=82
pageleft=33
pageright=34
exitemulator=27
ingame=80
screenshot=83
screenshotbackglass=66
instructions=73
volumedown=109
volumeup=107
[JoyCodes]
quit=10
left=0
right=1
select=2
rotate=3
pageleft=4
pageright=5
exitemulator=6
ingame=13
instructions=14
[Text]
Line1=Free Play
Line2=Press Start
[FuturePinball]
Enabled=False
WorkingPath=h:\-PINBALL-\-FUTURE PINBALL-
TablePath=h:\-PINBALL-\-FUTURE PINBALL-\Tables
Executable=Future Pinball.exe
LaunchBeforeEnabled=false
LaunchBeforeWorkingPath=
LaunchBeforeHideWindow=False
LaunchBeforeWaitForExit=True
LaunchAfterEnabled=False
LaunchAfterWorkingPath=
LaunchAfterHideWindow=False
LaunchAfterWaitForExit=True
MouseClickFocus=True
[VisualPinball]
WorkingPath=C:\Program Files (x86)\Visual Pinball
TablePath=C:\Program Files (x86)\Visual Pinball\Tables
Executable=VPinball991.exe
[ExitScreen]
EnableExit=True
EnableShutdown=True
[StartupProgram]
Enabled=false
WorkingPath=
Paramaters=
HideWindow=true
WaitForExit=false
[ExitProgram]
Enabled=false
WorkingPath=
Paramaters=
HideWindow=False
WaitForExit=
[AttractMode]
Timer=1
ShowFor=15
MuteAudio=False
[System_1]
Name=Pinball FX2
Enabled=False
WorkingPath=C:\Steam
TablePath=C:\Steam\Tables
Executable=PinballFX.exe
Parameters=
SystemType=0
[System_2]
Name=MAME
Enabled=False
TablePath=C:\
Executable=mamep64.exe
Parameters=[TABLEFILE]
SystemType=0
[AutoExit]
Enabled=False
Minutes=10
[Login]
[Internal]
lastselected=Medieval Madness (Williams 1997)Medieval-Madness_VP91x_2.4.3FSVisualPinball
filter_year=
filter_company=
filter_custom=
filtername=Tables
lastwheelcachematchsize=-1123
[General]
Language=German
[SetupWizard]
EmuPath1=C:\Emulators
AssetPath1=C:\Assets
RomPath1=C:\Roms
DefaultPathPrompt=True
DownloadDatabasePrompt=True
DownloadEmulatorPrompt=True
WizardMode=1
CustomArray=
SearchArray=
SavePosition=False
SectionIndex=20
SearchText=
EmulatorIndex=0
EmulatorGroupIndex=0
DaphneIndex=0
HTMLAppsIndex=0
ExternalAppsIndex=0
RadioStationsIndex=0
NewsFeedsIndex=0
MappedDrivesIndex=0
SystemIndex=1
ShowPanel=True
FontSize=1
WindowState=0
WindowSize=929,708
WindowLocation=597,122
[GameListManager]
onlinemode=true
22:30:02.1 05.04.2015: PinballX - Version 1.98
22:30:02.1 05.04.2015: Windows 7 Home Premium Service Pack 1 64-Bit (3,998046875GB)
22:30:02.1 05.04.2015: Loading Settings
22:30:02.1 05.04.2015: Initialize Component
22:30:02.1 05.04.2015: Initialize Display
22:30:03.3 05.04.2015: Loading PlugIns
22:30:03.4 05.04.2015: Created DirectX BackGlass Window
22:30:03.4 05.04.2015: Created DirectX DMD Window
22:30:03.6 05.04.2015: Hiding Cursor
22:30:03.6 05.04.2015: Hiding Taskbar
22:30:03.6 05.04.2015: CPU: Intel(R) Core(TM)2 Quad CPU Q9300 @ 2.50GHz
22:30:03.6 05.04.2015: GPU 1: NVIDIA GeForce GTX 570
22:30:03.6 05.04.2015: Displays: 3
22:30:03.6 05.04.2015: Load Game List
22:30:03.7 05.04.2015: Loading Database: Pinball FX2
22:30:03.7 05.04.2015: Loading Database: Visual Pinball
22:30:03.7 05.04.2015: Finding and matching artwork and videos
22:30:03.7 05.04.2015: Loading Game Statistics and Scores
22:30:04.6 05.04.2015: Loading Surfaces
22:30:04.8 05.04.2015: Finished Loading Surfaces
22:30:04.8 05.04.2015: Initialize Audio
22:30:04.9 05.04.2015: Set Keyboard Controls
22:30:04.9 05.04.2015: Initialize Joystick
22:30:05.0 05.04.2015: No Joysticks Attached
22:30:05.0 05.04.2015: Started
22:30:33.2 05.04.2015: Exiting
22:30:33.5 05.04.2015: Showing Taskbar
22:30:33.5 05.04.2015: Unhiding Mouse Cursor
22:30:33.6 05.04.2015: Disposing Plugins
22:30:33.6 05.04.2015: Saving Settings
22:30:33.6 05.04.2015: Bye
I am sure someone will jump in that has DMD running. I don't so would not know exactly where to look myself (just now getting around to tinkering with PinballX a bit).
I guess, pinballx dont find / read the dmd files.
I take a look into the media Folder from VisualPinball in the pinballx root. All DMD Files for the tables are still there. I have donwload the realdmd and nonreal dmd file for all my tables and only two of them shown the nonreal DMD Image.
