I am a fan of the screensaver in GameEx. I love the way it displays all of the games from my favorites menu. The only thing I would like to do is to disable the sound it plays (Ms. Pac-Man sample) upon exiting the screensaver. Does anyone know how to do this?
Enter the gameex configuration window, select: Attract/Screensaver, then change 'Play Exit Sound' to 'No'.
If you just want to hear a different sound, then go to the themes folder, select the one you use, open the media folder, and replace the 'exitscreensaver.wav' with either 'launch.wav' or 'blank.wav'
