Just installed MAME 0.105 on computer running XP and a number of the games are running sideways on the screen.
Any suggestions on how to fix this would be appreciated.
Hi I have the same setup and and am having the same problem
Doug
Did you go intro the properties (of your version of MAME) and check out the screen (view/display) layout?
That fixed it! Went into properties/display and set Rotation to "None". Thanks for the help this has been driving me nuts!
Doug
Doug
Glad to help! I know I went crazy looking for the solution..then clued in after numerous hours..finally!
