Hi, I have some problems with the Front End PinballX.
No videos shows me the tables, but if the Backglass.
The instructions appear on the second monitor me, not the first.
All in folders that correspond, in fact, the Hyperpin me everything works fine ...
Any solution to these problems?
I have installed the latest version of PinballX
When reporting a possible bug or error, please submit a copy of the following files so we may quickly assist you:
For PinballX - pinballx.ini and log.txt (Click here for additional information on how to find these files and others that may be required)
Files.rar
Thanks, but if not too much trouble please place the pinballx.ini and log.txt files in spoiler tags per the instructions here. This will help us help you better and quicker. Thanks!
PinballX.ini
[Display]
Monitor=0
Rotate=270
Windowed=False
WindowWidth=480
WindowHeight=720
WindowX=0
WindowY=65
PlayFieldBrightness=230
WheelTextColor=ffffffff
InfoTextColor=ffffffff
InfoTextOutlineColor=ff000000
FilterTextColor=ffffffff
MenuColor=ffffa500
FullScreenWindowed=True
[backGlass]
monitor=1
x=0
y=0
width=1600
height=900
[DMD]
Enabled=False
monitor=2
x=0
y=0
width=900
height=300
[FileSystem]
EnableFileMatching=True
[interface]
DesktopModeEnabled=False
EnableAdditionalDetail=True
ShowSystem=True
ShowRatings=True
[Audio]
StreamVolume=90
SampleVolume=90
PlaySoundInVideos=True
[startup]
playsound=True
playvideo=True
StartWithWindows=No
[KeyCodes]
quit=27
left=160
right=161
select=13
rotate=82
pageleft=33
pageright=34
exitemulator=27
ingame=80
screenshot=83
screenshotbackglass=66
instructions=73
[JoyCodes]
quit=10
left=0
right=1
select=2
rotate=3
pageleft=4
pageright=5
exitemulator=6
ingame=13
instructions=14
[Text]
Line1=Free Play
Line2=Press Start
[FuturePinball]
Enabled=False
WorkingPath=h:\-PINBALL-\-FUTURE PINBALL-
TablePath=h:\-PINBALL-\-FUTURE PINBALL-\Tables
Executable=Future Pinball.exe
LaunchBeforeEnabled=false
LaunchBeforeWorkingPath=
LaunchBeforeHideWindow=False
LaunchBeforeWaitForExit=True
LaunchAfterEnabled=False
LaunchAfterWorkingPath=
LaunchAfterHideWindow=False
LaunchAfterWaitForExit=True
MouseClickFocus=True
[VisualPinball]
WorkingPath=C:\Arcades\Visual Pinball
TablePath=C:\Arcades\Visual Pinball\Tables
Executable=VPinball.exe
NVRAMPath=C:\Arcades\Visual Pinball\nvram
[ExitScreen]
EnableExit=True
EnableShutdown=True
[startupProgram]
Enabled=false
WorkingPath=
Paramaters=
HideWindow=true
WaitForExit=false
[ExitProgram]
Enabled=False
WorkingPath=
Paramaters=
HideWindow=False
WaitForExit=
[AttractMode]
Timer=1
ShowFor=15
[system_1]
Name=Pinball FX2
Enabled=False
WorkingPath=C:\Steam
TablePath=C:\Steam\Tables
Executable=PinballFX.exe
Parameters=
[system_2]
Name=MAME
Enabled=False
TablePath=C:\
Executable=mamep64.exe
Parameters=[TABLEFILE]
[AutoExit]
Minutes=10
[Login]
Enabled=False
[internal]
lastselected=Bad Cats (Williams 1989)Bad CatsVisualPinball
filter_year=
filter_company=
filter_custom=
filtername=Tables
[General]
Language=Spanish
[setupWizard]
EmuPath1=C:\Emulators
AssetPath1=C:\Assets
RomPath1=C:\Roms
DefaultPathPrompt=True
DownloadDatabasePrompt=True
DownloadEmulatorPrompt=True
WizardMode=2
CustomArray=General Settings|Display Settings|Audio Settings|GameEx Online|Startup Settings|Keyboard Input Settings|Joystick Input Settings|Text|Future Pinball|Visual Pinball|Other Systems|Attract Mode|Auto Exit|Exit Screen|Exit Program
SearchArray=
SavePosition=False
SectionIndex=19
SearchText=
EmulatorIndex=0
EmulatorGroupIndex=0
DaphneIndex=0
HTMLAppsIndex=0
ExternalAppsIndex=0
RadioStationsIndex=0
NewsFeedsIndex=0
MappedDrivesIndex=0
SystemIndex=0
ShowPanel=False
FontSize=1
WindowState=2
WindowSize=650,478
WindowLocation=2395,211
[Plugin_1]
Enabled=False
Name=PlugInSpeech.dll
[Plugin_2]
Enabled=False
[Plugin_3]
Enabled=False
Name=Xpadder Plugin.dll
Log.txt
23:39:23.0 02/06/2014: PinballX - Version 1.85
23:39:23.0 02/06/2014: Loading Settings
23:39:23.0 02/06/2014: Initialize Component
23:39:23.1 02/06/2014: Initialize Display
23:39:23.1 02/06/2014: Loading PlugIns
23:39:23.4 02/06/2014: Created DirectX BackGlass Window
23:39:23.4 02/06/2014: Hiding Cursor
23:39:23.5 02/06/2014: Hiding Taskbar
23:39:23.5 02/06/2014: Load Game List
23:39:23.6 02/06/2014: Loading Database: Visual Pinball
23:39:23.6 02/06/2014: Finding and matching artwork and videos
23:39:23.8 02/06/2014: Loading Game Statistics and Scores
23:39:24.6 02/06/2014: Initialize Audio
23:39:24.7 02/06/2014: Set Keyboard Controls
23:39:24.7 02/06/2014: Initialize Joystick
23:39:24.8 02/06/2014: 1 Joysticks Attached
23:39:24.8 02/06/2014: Started
23:39:45.1 02/06/2014: Exiting
23:39:45.1 02/06/2014: Showing Taskbar
23:39:45.1 02/06/2014: Unhiding Mouse Cursor
23:39:45.1 02/06/2014: Disposing Plugins
23:39:45.1 02/06/2014: Saving Settings
Well, the videos of the tables is already fitted, install the Shark Codecs and everything works fine.
What I can not solve is that the cards appear Click on the monitor makes playfield, displayed on the monitor makes backglass .... any ideas?
