hi
when i run pinballx the mouse cursor is there how do you get rid off it. thanks anyone no.
You may want to refer to the How to Ask for Help thread and provide us with some information about your setup as instructed there and also let us know what OS you are running. Thanks!
ok thanks.
on win7 64bit the cursor shows when i run pinballx and the log says hiding cusor so dont no why it not hiding it.
ini
[Display]
Monitor=0
Rotate=270
Windowed=False
WindowWidth=480
WindowHeight=720
WindowX=0
WindowY=65
PlayFieldBrightness=230
WheelTextColor=ffffffff
InfoTextColor=ffffffff
InfoTextOutlineColor=ff000000
FilterTextColor=ffffffff
MenuColor=ffffa500
[backGlass]
monitor=1
x=0
y=0
width=1280
height=1024
[DMD]
Enabled=False
monitor=2
x=0
y=0
width=900
height=300
[FileSystem]
EnableFileMatching=False
[interface]
DesktopModeEnabled=False
EnableAdditionalDetail=False
ShowSystem=True
ShowRatings=True
[Audio]
StreamVolume=90
SampleVolume=90
PlaySoundInVideos=True
[startup]
playsound=False
playvideo=False
StartWithWindows=No
[KeyCodes]
quit=27
left=37
right=39
select=13
rotate=82
pageleft=38
pageright=40
exitemulator=27
ingame=90
screenshot=83
screenshotbackglass=66
instructions=73
[JoyCodes]
quit=
left=
right=
select=
rotate=
pageleft=
pageright=
exitemulator=
ingame=
instructions=
[Text]
Line1=Free Play
Line2=Press Start
[FuturePinball]
WorkingPath=C:\Games\Future Pinball\BAM
TablePath=C:\Games\Future Pinball\Tables
Executable=Future Pinball.exe
Parameters=/STAYINRAM /open "[TABLEPATH]\[TABLEFILE]" /play /exit /arcaderender
LaunchBeforeEnabled=false
LaunchBeforeWorkingPath=
LaunchBeforeHideWindow=False
LaunchBeforeWaitForExit=True
LaunchAfterEnabled=False
LaunchAfterWorkingPath=C:\Games\Future Pinball
LaunchAfterExecutable=Click.exe
LaunchAfterHideWindow=False
LaunchAfterWaitForExit=True
MouseClickFocus=True
FPRAMPath=C:\Games\Future Pinball\fpRAM
[VisualPinball]
WorkingPath=C:\Program Files (x86)\Visual Pinball
TablePath=C:\Program Files (x86)\Visual Pinball\Tables
Executable=VP9_DX9_test11.exe
NVRAMPath=C:\Program Files (x86)\Visual Pinball\VPinMame\nvram
[ExitScreen]
EnableExit=True
EnableShutdown=True
[startupProgram]
Enabled=false
WorkingPath=
Paramaters=
HideWindow=true
WaitForExit=false
[ExitProgram]
Enabled=false
WorkingPath=
Paramaters=
HideWindow=False
WaitForExit=
[AttractMode]
Timer=1
ShowFor=15
[system_1]
Name=PinballFX2
WorkingPath=C:\PinballFX2
TablePath=C:\PinballFX2\data_steam
Executable=Pinball FX2.exe
Parameters=
LaunchBeforeEnabled=True
LaunchBeforeWorkingPath=C:\PinballX\Scripts
LaunchBeforeExecutable=PinballFX2.exe
LaunchBeforeParameters=[TABLEFILE]
LaunchBeforeWaitForExit=False
LaunchAfterWorkingPath=C:\PinballX\Scripts
LaunchAfterExecutable=ledset.bat
LaunchAfterHideWindow=True
LaunchAfterWaitForExit=False
[system_2]
Name=MAME
WorkingPath=C:\MAME
TablePath=C:\MAME\DUMMYROMS
Executable=MAME.exe
LaunchBeforeEnabled=False
[AutoExit]
Enabled=False
Minutes=10
[Login]
Enabled=False
[internal]
lastselected=LooterLooterSystem_1
filter_year=
filter_company=
filter_custom=Zen Pinball FX2
filtername=Zen Pinball FX2 Tables
[setupWizard]
EmuPath1=C:\Emulators
AssetPath1=C:\Assets
RomPath1=C:\Roms
DefaultPathPrompt=True
DownloadDatabasePrompt=True
DownloadEmulatorPrompt=True
WizardMode=1
CustomArray=
SearchArray=
SavePosition=False
SectionIndex=12
SearchText=
EmulatorIndex=0
EmulatorGroupIndex=0
DaphneIndex=0
HTMLAppsIndex=0
ExternalAppsIndex=0
RadioStationsIndex=0
NewsFeedsIndex=0
MappedDrivesIndex=0
SystemIndex=0
ShowPanel=True
FontSize=1
WindowState=0
WindowSize=650,930
WindowLocation=430,68
[Plugin_1]
Enabled=False
Name=PlugInSpeech.dll
[Plugin_2]
Enabled=False
[Plugin_3]
Enabled=False
Name=Xpadder Plugin.dll
[system_3]
Name=Jukebox
WorkingPath=C:\Games\Jukebox
TablePath=C:\Games\Jukebox\Tables
Executable=Jukebox.exe
Parameters=
[system_4]
Name=The Pinball Arcade
WorkingPath=C:\The Pinball Arcade
TablePath=C:\The Pinball Arcade\Resource
Executable=PinballArcade.exe
Parameters=
LaunchBeforeExecutable=The Pinball Arcade.exe
log
17:47:27.0 23/03/2014: PinballX - Version 1.77
17:47:27.0 23/03/2014: Loading Settings
17:47:27.0 23/03/2014: Initialize Component
17:47:27.0 23/03/2014: Initialize Display
17:47:27.1 23/03/2014: Loading PlugIns
17:47:27.5 23/03/2014: Created DirectX BackGlass Window
17:47:27.6 23/03/2014: Hiding Cursor
17:47:27.6 23/03/2014: Hiding Taskbar
17:47:27.6 23/03/2014: Load Game List
17:47:27.6 23/03/2014: Loading Database: Future Pinball
17:47:27.6 23/03/2014: Loading Database: Visual Pinball
17:47:27.6 23/03/2014: Loading Database: PinballFX2
17:47:27.6 23/03/2014: Loading Database: MAME
17:47:27.6 23/03/2014: Loading Database: Jukebox
17:47:27.6 23/03/2014: Loading Database: The Pinball Arcade
17:47:27.6 23/03/2014: Loading Custom Database: Future Pin
17:47:27.6 23/03/2014: Loading Custom Database: Zen Pinball FX2
17:47:27.7 23/03/2014: Loading Custom Database: Vertical Mame
17:47:27.7 23/03/2014: Loading Custom Database: My Jukebox
17:47:27.7 23/03/2014: Loading Custom Database: Pinball Arcade
17:47:27.7 23/03/2014: Finding and matching artwork and videos
17:47:27.8 23/03/2014: Loading Game Statistics and Scores
17:47:28.8 23/03/2014: Initialize Audio
17:47:28.8 23/03/2014: Set Keyboard Controls
17:47:28.8 23/03/2014: Initialize Joystick
17:47:28.9 23/03/2014: No Joysticks Attached
17:47:28.9 23/03/2014: Started
17:49:47.7 23/03/2014: Launch System
17:49:47.7 23/03/2014: Waiting for threads
17:49:47.7 23/03/2014: Disposing display
17:49:48.9 23/03/2014: C:\PinballX\Scripts\PinballFX2.exe Looter
17:49:48.9 23/03/2014: C:\PinballFX2\Pinball FX2.exe
17:50:20.5 23/03/2014: Exit System Control Pressed
17:50:23.3 23/03/2014: Created DirectX BackGlass Window
17:50:27.2 23/03/2014: Exiting
17:50:27.3 23/03/2014: Showing Taskbar
17:50:27.3 23/03/2014: Unhiding Mouse Cursor
17:50:27.3 23/03/2014: Disposing Plugins
17:50:27.3 23/03/2014: Saving Settings
I've been playing around with this on my system as well. Mine won't hide no matter what I try. I have a dedicated cabinet, so after I'm done with all of my configuration I'll remove all Microsoft and Windows branding, install transparent cursors, and just have it boot directly into PinballX. The cursor will still be there, but it will be invisible. I have Windows 7 Ultimate 64-bit.
its ok i have fixed it myself with a workround have used nomousey.exe /hide and added it ti the pinball.bat file and that worked. and in the pinballx setup i av run the nomousey.exe for exit program to run to restore the mouse and its working ok with that.
With mine, the mouse cursor in PinballX is where ever it was when I launched the software. Once I open a table in VP9 it centers the cursor in the middle of the playfield monitor. I think there's a problem hiding the cursor in Windows 7 because VP9 can't hide it either.
mine wos within pinballX but it ok now with the workround i did. it wos ok in VP ect just showed in PinballX.
