Ok I have been trying to make the switch from HP to PX I have everything working now just have one issue with the loading screen.
Is there any way I can leave the images of the tables and backglass without my screen turning black or change the amount of time that the loading splash screen stays up?
Also when I load a FX2 table how do i get the backglass and dmd to stay up.. it goes black.
Thanks for the great program seems to be running smooth..
I can answer your second question......In your Pinball FX2.xml file set your <hidedmd> and <hidebackglass> to FALSE
<menu>	<game name="MARVEL_DrStrange">		<description>Marvel - Dr Strange</description>		<manufacturer>Zen</manufacturer>		<year>2013</year>		<type>SS</type>		<hidedmd>False</hidedmd>		<hidebackglass>False</hidebackglass>		<enabled>True</enabled>		<rating>0</rating>	</game>	<game name="MARVEL_Blade">		<description>Marvel - Blade</description>		<manufacturer>Zen</manufacturer>		<year>2013</year>		<type>SS</type>		<hidedmd>False</hidedmd>		<hidebackglass>False</hidebackglass>		<enabled>True</enabled>		<rating>0</rating>	</game>	<game name="MARVEL_CaptainAmerica">		<description>Marvel - Captain America</description>		<manufacturer>Zen</manufacturer>		<year>2013</year>		<type>SS</type>		<hidedmd>True</hidedmd>		<hidebackglass>False</hidebackglass>		<enabled>True</enabled>		<rating>0</rating>	</game>
If you open your *.xml files in gamemanager (inside the PBX dir) it will add the extra lines.
Z
The loading screen covers any background programs loading up (eg visual pinball editor) before the table is launched. You can always just create a custom one like I did to suit your cabinet.
