Hi all, trying to switch from hyperpin to pinball X and having an issue. I can load information and tables etc for VP and FP and play those tables properly.
The problem I am having is that when I set up pinball X. I turned on FP, VP, and third setup screen which is Pinball FX2 emulators.
When Pinball X is loaded I dont have the option to load any pinball fx 2 tables......its like the emulator was not turned on in the setup of pinball X?
Any help would be appreciated.
Thanks!
I will refer you to this thread - lots of good stuff. If you are having any issues with any of the recommendations, that would be a good thread to post your reply.
