Hi to all! Can I ask a courtesy from you? Has anyone the necessary tools for converting the default theme (800x600), that i really like, into a 640x480 version? I've tried with ThemeEditor but it isn't possible reproducing some things (as the smart behavior of the description popup).
There isn't too choice, for the owners of old arcade cabinet, among the themes available in the apposite section.
Bye and thanks!
The only way to do this is do it yourself in a program like Paint or Photoshop. Changing the fields in the Theme Editor is simple enough, but all the artwork needs to be resized as well. If you're lucky, the original creator may be nice enough to do the work for you and release a lower resolution version.
