Hi guys! Do you say how configure joypad controls in this emulator? When i configure the set remain only for the game that i loaded...
What I did was load each game, then set the control's for that game. It is time consuming but I'm not sure of another way.
I know for example if you were to load sf2 then edit the control's and save them, then If you copied the config for sf2 and renamed it to sf2ce, the same controls would work for sfc2e but this method does not work with all games.
Yes, it doesn't take too long though, The time depends on what rom set you are using.
