I am having an issue with my game card. I have noticed that it does not update so I went to get a new one.
It is giving me a card with a different user name on it.
It has been a while but I think at one time I used this as a user name but can not remember.
I would like to be able to use my regular username on the card.
Please help
Rodger (R-DuB)
http://www.gameex.com/community/gamecards.aspx?gamecard=1&id=Carcass
Hi, it does not really help I know but I just tested things and everything appears to be working. Couple of things to try are - install the registry file from the desktop, ensure your GameEx version is recent, check for firewall issues.
Also you can get it to send you a replacement card by using your email address.
Yea I have done this, odd that it gives me the same thing, a card with tag name of carcass no matter what.
Oh well no big deal I guess.
Thanks anyway
If you could that would be great. I would like it to be RDuB if you would Thanks
