Hi! I'm italian user... I have a problem with my new frontend gameex! The .sav files of visual boy advance and .srm files of snes are visible in rom list. How can i fix? I do not want double degrees...
Help me!
Hey,
You may have to configure your emulators to save your save states to another folder.
As suggested, moving the location of those files and setting in the emulator itself is the best way. But to filter them out, you can always just add a filter to the list so that they don't show (i.e "*.zip" will show all zip files only).
I haven't zip file but only gb or gbc or gba file... If i set RomFilter=*.gb;*.gbc;*.gba the frontend don't find all roms...
Does it rebuild the list though based off those options?
Could you upload a copy of the emulator config file?
Goron - please provide copies of your gameex.ini and emulator config file. for GBA.
When reporting a possible GameEx bug or error, please ensure you submit a copy of your log.txt and gameex.ini file so we may quickly assist you. Please refer to this link for additional information on how to find these files.
It's worth checking the extension(s) of your roms if some of them are still not showing.
Navigate to your rom folder, Right click in that rom folder and click on sort by type and see if there are any extra extensions which you are not aware of, If there are just add them to the "Rom Filter" in the setup wizard
