Update: Another similar issue.
I want to change the big videopreview on background in mame and so i've played with "Display Image/VIdeo List". No effects.
Then i've tried to switch off "Hide Change View"; in GameEx I've changed view, i've gone out, restarted GameEx but the view is the same of the beginning...
It seems to me that some features of the SetupWizard don't have any effect.
Some times you have to hit Change View quite a few times to get the view you desire. When reporting a possible GameEx bug or error, please ensure you submit a copy of your log.txt and gameex.ini file so we may quickly assist you. Please refer to this link for additional information.
Ehm... i was playing with wrong option! The right one is "Background mode" in "Display settings" section.
Bye!
Sang victory too soon! I'm going crazy! Now with the switching "change view" i can't find anymore my best option (the standard one: two small snap on the side). Simply, is it as if it doesn't exist....
I don't understand the logical of the options...
At this point is useless that i post my config file. It's all tangled!
All the more reason to submit the requested files. This aids us tremendously with untangling things. Thanks!
Here the config:
GameEx.txt
Log:
19:17:12.3 26/04/2013: Opening Configuration File
19:17:12.4 26/04/2013: GameEx: Version 13.10: Starting Log
19:17:12.4 26/04/2013: Operating System Platform: Win32NT
19:17:12.4 26/04/2013: Operating System Name: Windows 7
19:17:12.4 26/04/2013: Operating System Version: 6.1.7601
19:17:12.4 26/04/2013: Aero running
19:17:12.4 26/04/2013: Initializing Vista/Windows 7 volume control
19:17:12.4 26/04/2013: Getting CPU and RAM info
19:17:12.4 26/04/2013: Intel® Core i7 CPU 860 @ 2.80GHz, 4087MB
19:17:12.4 26/04/2013: 2,81Ghz - 8 Cores or CPU's
19:17:12.4 26/04/2013: Running Randomize()
19:17:12.4 26/04/2013: Loading PlugIns
19:17:12.4 26/04/2013: Checking for applications to Launch On Startup
19:17:12.4 26/04/2013: Setting default net connection limit to 15
19:17:12.4 26/04/2013: Running Misc startup tasks
19:17:12.4 26/04/2013: Setting Menu types
19:17:12.4 26/04/2013: Getting Configuration Values
19:17:12.4 26/04/2013: Using Theme: Default - Default
19:17:12.4 26/04/2013: Checking for alternate Image Directory for Theme: Default - Default
19:17:12.4 26/04/2013: Launching HideOS.exe
19:17:12.4 26/04/2013: Initialising Video/MNG DLL's
19:17:12.4 26/04/2013: Arcade Mode is on
19:17:12.4 26/04/2013: Hiding Taskbar
19:17:12.6 26/04/2013: Using Cabinet Friendly Control System
19:17:12.6 26/04/2013: Is Media Center running?
19:17:12.6 26/04/2013: Checking/Creating LCD Registry values
19:17:12.6 26/04/2013: Check Media Center Exit/Start Mode
19:17:12.6 26/04/2013: Media Center Mode 2
19:17:12.6 26/04/2013: Video previews on. Warning: Only recommended on modern systems
19:17:12.6 26/04/2013: Custom Keyboard Input enabled: Getting custom codes
19:17:12.6 26/04/2013: Snap Delay set to: 4
19:17:12.6 26/04/2013: Get other settings
19:17:12.6 26/04/2013: Desktop set to Hide ICONS and set Background to Black
19:17:12.6 26/04/2013: Set: Find emulator artwork on best match basis
19:17:12.6 26/04/2013: SlikStik support enabled
19:17:12.6 26/04/2013: Using DirectInput for keyboard input
19:17:12.6 26/04/2013: Start work for Form
19:17:12.6 26/04/2013: Getting Original Screen Size
19:17:12.6 26/04/2013: Opening Database Connection
19:17:12.7 26/04/2013: Initializing Component
19:17:12.7 26/04/2013: MAME Path is: D:\Arcade Cab\Mame 0.148
19:17:12.7 26/04/2013: Model 2 Path Path is: C:\Emulators\Model2
19:17:12.7 26/04/2013: Cannot Find Model 2 Path
19:17:12.7 26/04/2013: Disabling Model 2 support
19:17:12.7 26/04/2013: MAME EXE file is: MAMEUI32.exe
19:17:12.7 26/04/2013: ROM Path is: D:\Arcade Cab\Mame 0.148\roms Set Completo alla 0.148 (No CHD)
19:17:12.7 26/04/2013: Catver.ini is located at: D:\GameEx\DATA\CatverITA0.148_1.ini
19:17:12.7 26/04/2013: History.dat is located at: D:\GameEx\DATA\historyITAmod.dat
19:17:12.7 26/04/2013: nplayers.ini is located at: D:\GameEx\DATA\nplayers0.148.ini
19:17:12.7 26/04/2013: command.dat is located at: D:\GameEx\DATA\command.dat
19:17:12.7 26/04/2013: MAMEinfo.dat Not Found
19:17:12.7 26/04/2013: Loading Controls.ini map file
19:17:12.7 26/04/2013: Snap Path is: D:\Arcade Cab\Mame 0.148\snap\InGame AntoPisa 0.148
19:17:12.8 26/04/2013: Background Snap Path is: D:\Arcade Cab\Mame 0.148\snap\InGame AntoPisa 0.148
19:17:12.8 26/04/2013: AVI Snap Path is: D:\Arcade Cab\Mame 0.148\video
19:17:12.8 26/04/2013: Flyer Path is: D:\Arcade Cab\Mame 0.148\snap\Flyers AntoPisa 0.148_4
19:17:12.8 26/04/2013: Cabinet Path is: D:\Arcade Cab\Mame 0.148\snap\Cabinet AntoPisa 0.148_2
19:17:12.8 26/04/2013: Cabinet 3D Path: Not Found
19:17:12.8 26/04/2013: Title Path is: D:\Arcade Cab\Mame 0.148\snap\Titles AntoPisa 0.148
19:17:12.8 26/04/2013: PCB Path: Not Found
19:17:12.8 26/04/2013: Artwork Preview Path is: D:\Arcade Cab\Mame 0.148\snap\Artwork Preview AntoPisa 0.148
19:17:12.8 26/04/2013: Panel Path is: D:\Arcade Cab\Mame 0.148\snap\Control Panel AntoPisa 0.148
19:17:12.8 26/04/2013: Manual Path: Not Found
19:17:12.8 26/04/2013: Icon Path: Not Found
19:17:12.8 26/04/2013: Marquee Path is: D:\Arcade Cab\Mame 0.148\snap\Marquee AntoPisa 0.148
19:17:12.8 26/04/2013: Applying Language/Text
19:17:12.8 26/04/2013: Text/Language: Custom
19:17:12.8 26/04/2013: Loading Language/Text
19:17:12.8 26/04/2013: Loading Custom Emulators
19:17:12.8 26/04/2013: Loading Emulator 1: Capcom Play System 3
19:17:12.8 26/04/2013: Loading Emulator 2: Sega NAOMI
19:17:12.8 26/04/2013: Loading Emulator 3: Sammy Atomiswave
19:17:12.8 26/04/2013: Loading Emulator 5: NullDC
19:17:12.8 26/04/2013: Loading Emulator 6: Makaron
19:17:12.8 26/04/2013: Checking if Steam enabled
19:17:12.8 26/04/2013: Steam is installed correctly
19:17:12.8 26/04/2013: Invalid or filtered path: c:\\program files (x86)\\skyrim\\steamapps\\ottolola\\winui
19:17:12.8 26/04/2013: Directory does not exist: c:\\program files (x86)\\skyrim\\steamapps\\ottolola\\valvetestapp207510
19:17:12.8 26/04/2013: Did not find any Steam games
19:17:12.8 26/04/2013: Loading Emulator Group 1: Sega NAOMI
19:17:12.8 26/04/2013: Using 3D Alpha Blended Animations.
19:17:12.8 26/04/2013: Retrieving resolution setting
19:17:12.8 26/04/2013: Using General Font: Trebuchet MS
19:17:12.8 26/04/2013: Using Title Font: Trebuchet MS
19:17:12.8 26/04/2013: GameEx will try to reduce CPU usage
19:17:13.3 26/04/2013: Initialising Direct3D
19:17:13.5 26/04/2013: Mouse Input is disabled
19:17:13.6 26/04/2013: Setting Resolution to 640x480 32 bit color
19:17:13.6 26/04/2013: Creating Surfaces
19:17:14.7 26/04/2013: Creating Primary Surface - Full Screen Mode
19:17:14.7 26/04/2013: Creating Back Buffer
19:17:14.8 26/04/2013: Loading graphic Surfaces
19:17:14.8 26/04/2013: Display is running at: 640x480 32bit color, 59hz
19:17:14.8 26/04/2013: Adapter: ATI Radeon HD 5800 Series
19:17:14.8 26/04/2013: Max texture size: 16384x16384
19:17:14.8 26/04/2013: Available texture memory: -1298MB
19:17:14.8 26/04/2013: Initialising Bass Audio Library
19:17:15.0 26/04/2013: Creating Surfaces Misc and Dialogs
19:17:15.1 26/04/2013: Creating Surfaces Volume
19:17:15.1 26/04/2013: Creating Surfaces Arrows
19:17:15.1 26/04/2013: Creating Surfaces GameEXlogo Text
19:17:15.1 26/04/2013: Creating Surfaces Toolbar
19:17:15.2 26/04/2013: Creating Surfaces Toolbar Controls
19:17:15.2 26/04/2013: Creating Surfaces Backgrounds
19:17:15.2 26/04/2013: Creating Surfaces GameEx Logo
19:17:15.2 26/04/2013: Creating Surface Unselected
19:17:15.2 26/04/2013: Creating Surfaces Snaps
19:17:15.2 26/04/2013: Creating Surfaces Menu and List Bars
19:17:15.3 26/04/2013: Creating Fonts
19:17:15.3 26/04/2013: Creating Game Font
19:17:15.5 26/04/2013: Creating Game Font Faded
19:17:15.6 26/04/2013: Creating Title Font
19:17:15.6 26/04/2013: Restoring Title Font From Cache
19:17:15.7 26/04/2013: Creating Font Black
19:17:15.8 26/04/2013: Creating Font Black Small
19:17:15.8 26/04/2013: Fonts Created Succesfully
19:17:16.0 26/04/2013: Attempting to load game list
19:17:16.1 26/04/2013: MAME CMD options: -nowindow -joy -skip_gameinfo
19:17:16.5 26/04/2013: Cannot Load Play List. Check Path and filename
19:17:16.5 26/04/2013: Gamepad/Joystick disabled
19:17:16.5 26/04/2013: Initialising DirectInput for Keyboard support
19:17:16.5 26/04/2013: Loading Start Page
19:17:16.5 26/04/2013: Initializing MCE Remote
19:17:16.5 26/04/2013: Playing intro sound file
19:17:16.6 26/04/2013: Initialization OK! Starting GameEx!
19:17:16.6 26/04/2013: Testing Main Loop Once: Processing Frame
19:17:17.0 26/04/2013: Testing Main Loop Once: Main Loop ran successfully
19:17:17.9 26/04/2013: Validating: Emulator_1: Custom Background: cps3800x600.png
19:17:17.9 26/04/2013: Validating: Emulator_1: Snap Path: D:\Arcade Cab\CPS3\Media\Snap
19:17:17.9 26/04/2013: Warning: Emulator_1: Snap Path Does not exist
19:17:17.9 26/04/2013: Validating: Emulator_1: Video Snap Path: D:\Arcade Cab\CPS3\Media\Video
19:17:17.9 26/04/2013: Validating: Emulator_1: Custom Art Path 1: D:\Arcade Cab\Mame 0.148\snap\Flyers AntoPisa 0.148_4
19:17:17.9 26/04/2013: Validating: Emulator_1: Custom Art Path 2: D:\Arcade Cab\Mame 0.148\snap\Cabinet AntoPisa 0.148_2
19:17:17.9 26/04/2013: Validating: Emulator_1: Custom Art Path 3: D:\Arcade Cab\Mame 0.148\snap\Marquee AntoPisa 0.148
19:17:17.9 26/04/2013: Validating: Emulator_1: Custom Art Path 4: D:\Arcade Cab\Mame 0.148\snap\Control Panel AntoPisa 0.148
19:17:17.9 26/04/2013: Validating: Emulator_1: Custom Art Path 5: Artwork Preview AntoPisa 0.148
19:17:17.9 26/04/2013: Warning: Emulator_1: Custom Art Path 5 Does not exist
19:17:17.9 26/04/2013: Validating: Emulator_1: Database: [Arcade] Romset completo 0.148
19:17:17.9 26/04/2013: Validating: Emulator_1: Title Snap Path: D:\Arcade Cab\Mame 0.148\snap\Titles AntoPisa 0.148
19:17:17.9 26/04/2013: Caching Video Snap Path
19:17:17.9 26/04/2013: Caching Snap Path
19:17:17.9 26/04/2013: Caching Title Path
19:17:17.9 26/04/2013: Validating: Emulator_2: Snap Path: D:\Arcade Cab\Demul\Media\Naomi\In Game
19:17:17.9 26/04/2013: Validating: Emulator_2: Video Snap Path: D:\Arcade Cab\Demul\Media\Naomi\Video
19:17:17.9 26/04/2013: Validating: Emulator_2: Custom Art Path 1: D:\Arcade Cab\Mame 0.148\snap\Flyers AntoPisa 0.148_4
19:17:17.9 26/04/2013: Validating: Emulator_2: Custom Art Path 2: D:\Arcade Cab\Mame 0.148\snap\Cabinet AntoPisa 0.148_2
19:17:17.9 26/04/2013: Validating: Emulator_2: Custom Art Path 3: D:\Arcade Cab\Mame 0.148\snap\Marquee AntoPisa 0.148
19:17:17.9 26/04/2013: Validating: Emulator_2: Custom Art Path 4: D:\Arcade Cab\Mame 0.148\snap\Control Panel AntoPisa 0.148
19:17:17.9 26/04/2013: Validating: Emulator_2: Custom Art Path 5: Artwork Preview AntoPisa 0.148
19:17:17.9 26/04/2013: Warning: Emulator_2: Custom Art Path 5 Does not exist
19:17:17.9 26/04/2013: Validating: Emulator_2: Database: [Arcade] Romset completo 0.148
19:17:17.9 26/04/2013: Validating: Emulator_2: Title Snap Path: D:\Arcade Cab\Mame 0.148\snap\Titles AntoPisa 0.148
19:17:17.9 26/04/2013: Validating: Emulator_3: Snap Path: D:\Arcade Cab\Demul\Media\Atomiswave\In Game
19:17:17.9 26/04/2013: Validating: Emulator_3: Video Snap Path: D:\Arcade Cab\Demul\Media\Atomiswave\Video
19:17:17.9 26/04/2013: Validating: Emulator_3: Custom Art Path 1: D:\Arcade Cab\Mame 0.148\snap\Flyers AntoPisa 0.148_4
19:17:17.9 26/04/2013: Validating: Emulator_3: Custom Art Path 2: D:\Arcade Cab\Mame 0.148\snap\Cabinet AntoPisa 0.148_2
19:17:17.9 26/04/2013: Validating: Emulator_3: Custom Art Path 3: D:\Arcade Cab\Mame 0.148\snap\Marquee AntoPisa 0.148
19:17:17.9 26/04/2013: Validating: Emulator_3: Custom Art Path 4: D:\Arcade Cab\Mame 0.148\snap\Control Panel AntoPisa 0.148
19:17:17.9 26/04/2013: Validating: Emulator_3: Custom Art Path 5: Artwork Preview AntoPisa 0.148
19:17:17.9 26/04/2013: Warning: Emulator_3: Custom Art Path 5 Does not exist
19:17:17.9 26/04/2013: Validating: Emulator_3: Database: [Arcade] Romset completo 0.148
19:17:17.9 26/04/2013: Validating: Emulator_3: Title Snap Path: D:\Arcade Cab\Mame 0.148\snap\Titles AntoPisa 0.148
19:17:17.9 26/04/2013: Validating: Emulator_5: Snap Path: D:\Arcade Cab\NullDC\EmuCR-nullDC-Naomi-r150\Roms\Media\Snap
19:17:17.9 26/04/2013: Validating: Emulator_5: Video Snap Path: D:\Arcade Cab\NullDC\EmuCR-nullDC-Naomi-r150\Roms\Media\Video
19:17:17.9 26/04/2013: Validating: Emulator_5: Custom Art Path 1: D:\Arcade Cab\Mame 0.148\snap\Flyers AntoPisa 0.148_4
19:17:17.9 26/04/2013: Validating: Emulator_5: Custom Art Path 2: D:\Arcade Cab\Mame 0.148\snap\Cabinet AntoPisa 0.148_2
19:17:17.9 26/04/2013: Validating: Emulator_5: Custom Art Path 3: D:\Arcade Cab\Mame 0.148\snap\Marquee AntoPisa 0.148
19:17:17.9 26/04/2013: Validating: Emulator_5: Custom Art Path 4: D:\Arcade Cab\Mame 0.148\snap\Control Panel AntoPisa 0.148
19:17:17.9 26/04/2013: Validating: Emulator_5: Database: [Arcade] Romset completo 0.148
19:17:17.9 26/04/2013: Validating: Emulator_5: Title Snap Path: D:\Arcade Cab\Mame 0.148\snap\Titles AntoPisa 0.148
19:17:17.9 26/04/2013: Validating: Emulator_6: Snap Path: D:\Arcade Cab\NullDC\EmuCR-nullDC-Naomi-r150\Roms\Roms Makaron\Media\Snap
19:17:17.9 26/04/2013: Validating: Emulator_6: Video Snap Path: D:\Arcade Cab\NullDC\EmuCR-nullDC-Naomi-r150\Roms\Roms Makaron\Media\Video
19:17:17.9 26/04/2013: Validating: Emulator_6: Custom Art Path 1: D:\Arcade Cab\Mame 0.148\snap\Flyers AntoPisa 0.148_4
19:17:17.9 26/04/2013: Validating: Emulator_6: Custom Art Path 2: D:\Arcade Cab\Mame 0.148\snap\Cabinet AntoPisa 0.148_2
19:17:17.9 26/04/2013: Validating: Emulator_6: Custom Art Path 3: D:\Arcade Cab\Mame 0.148\snap\Marquee AntoPisa 0.148
19:17:17.9 26/04/2013: Validating: Emulator_6: Custom Art Path 4: D:\Arcade Cab\Mame 0.148\snap\Control Panel AntoPisa 0.148
19:17:17.9 26/04/2013: Validating: Emulator_6: Database: [Arcade] Romset completo 0.148
19:17:17.9 26/04/2013: Validating: Emulator_6: Title Snap Path: D:\Arcade Cab\Mame 0.148\snap\Titles AntoPisa 0.148
19:17:17.9 26/04/2013: Restoring Emulator Database From Cache: 1
19:17:17.9 26/04/2013: Restoring Emulator Database From Cache: 2
19:17:17.9 26/04/2013: Restoring Emulator Database From Cache: 3
19:17:18.0 26/04/2013: Restoring Emulator Database From Cache: 5
19:17:18.0 26/04/2013: Restoring Emulator Database From Cache: 6
19:18:12.9 26/04/2013: Exiting GameEx!
19:18:12.9 26/04/2013: Disposing all videos
19:18:13.0 26/04/2013: Deleting temporary Karaoke videos
19:18:13.0 26/04/2013: Disposing Image List
19:18:13.0 26/04/2013: Disposing Fonts
19:18:13.0 26/04/2013: Disposing Surfaces
19:18:13.0 26/04/2013: Saving Settings
19:18:13.1 26/04/2013: Shutting down Bass
19:18:13.4 26/04/2013: Closing HideOS.exe
19:18:13.6 26/04/2013: Disposing Plugins
19:18:13.6 26/04/2013: Closing database connection
19:18:13.6 26/04/2013: Checking for applications to Launch On Exit
19:18:13.6 26/04/2013: Media Center was not open when starting GameEx, so not launching
19:18:13.6 26/04/2013: Bye
:wacko::)
