Not sure if this is the place to come or not as I went to CPwizard's site and did not really find a forum so I thought I'd try you guys.
For the most part the default control list is fine. But then I come across MK Series and NBA Jam and I want to change those games to a certain layout that differs from the default. I take it I need to create a layout for each of these games but how does the "default" layout or setting pull my custom layouts to display? I'm not sure if I am wording this right or not.
Thanks,
Rich
The Author of CPWizard is Headkaze who is a member here. You can find a list of his projects HERE.
You may find the answer you need in the CPWizard topic, if not you can ask your question in that thread.
Having said that, it has been a long time since I set up CPWizard, but I think that there is something called Layout Overrides, which may be what you are looking for.
