[RESOLVED] Problem with a few game lists and themes after updates
After updating gameex a few versions ago (including the most recent), two of my emulators display all the game lists just fine, but when you select a game, the games name is blue (not white), and it cannot be selected to play. This is only an issue with my N64 (project64) and SNES (zsnes) emulators. Both emulators work fine outside of GameEx.
The other issue I am having concerns themes. I am trying to just use the default animated theme with only the blue backround. I can't seem to get rid of the game flyers, etc in the background or the black image. I've redownloaded all the themes, and I've tried all 3 options in the advanced config concerning theme backgrounds, but I've had no success.
Any help would be appreciated.
GameEx.ini
Is this occurring on the start pageoor within certain places when you load GameEx? Likely you will just need to click on Change View on the menu bar until you get the desired display.
Also, we are now at version 12.03. Please install the latest version and provide an updated log file.
Only 13.02 is listed in the download section. I do not see 13.03 anywhere.
Okay, this is fixed. It was just cycling through the "Change View" options. Thanks!
Tom announced the release of 13.03 earlier today so the page info may not yet be updated in kind. Let's give it a little time to update.
GameEx Help is still showing version 13.02 as well as log.txt. So one of two things has occurred: 13.03 is not on the site or it is but reflects an incorrect version. I am going to go with my original stance at this point, Krak.
OK< 13.03 is now showing available - Jombee, please update and report back with a new copy of your log.txt file. Thanks!
Okay, updated to 13.03, and same exact problem with games.
All the games appear just fine on the list, but after you select the game and go to the next screen, the game's name is blue, not white, and it cannot be selected to play. This is only happening with N64 and SNES. Updated log and ini is attached.
GameEx.ini
Update
Didn't hear back from anyone, so I decided to just redo each emulator from scratch.
They are now working fine, but I don't understand why updating GameEx caused this problem.
Edited by nullPointer
This topic has been marked as RESOLVED and is now closed. Please begin a new thread if you are experiencing any similar issues.
