Is your art not downloading? Could you try and run the standalone app and confirm you can see the directories? I'm pretty sure it works OK for me. :)
Ok, I figured it out. In the gameex folder there is a download utility app. Open that up and you can test your login. So glad when I can answer my own questions :)
Yup that's why I asked if you can see the directories on the standalone app. GameEx however uses the EmuMovies API for this so you're not really testing it through GameEx.
