How can I get Gameex to start when I keep getting the following error?
13:05:14.7 2/26/2006: GameEx: Version 5.74: Starting Log
13:05:14.8 2/26/2006: Operating System Platform: Win32NT
13:05:14.8 2/26/2006: Operating System Name: Windows XP
13:05:14.8 2/26/2006: Operating System Version: 5.1.2600
13:05:14.8 2/26/2006: Checking for versions of .net Framework installed
13:05:14.8 2/26/2006: .net Framework 1.1 Installed
13:05:14.8 2/26/2006: .net Framework 2.0 Installed
13:05:14.8 2/26/2006: Checking Registration
13:05:14.8 2/26/2006: Running Randomize()
13:05:14.8 2/26/2006: Initialising Video/MNG DLL's
13:05:14.8 2/26/2006: Running Misc startup tasks
13:05:14.8 2/26/2006: Setting Menu types
13:05:14.8 2/26/2006: Opening Configuration File
13:05:14.8 2/26/2006: Getting Configuration Values
13:05:14.8 2/26/2006: Using Theme: Default - Default
13:05:14.8 2/26/2006: Checking for alternate Image Directory for Theme: Default - Default
13:05:14.8 2/26/2006: Text/Language: English
13:05:14.8 2/26/2006: Applying Language/Text
13:05:14.9 2/26/2006: Creating Scancodes.txt (List of DirectInput scan codes)
13:05:14.9 2/26/2006: Snap Delay set to: 1
13:05:14.9 2/26/2006: Is Media Center running?
13:05:14.9 2/26/2006: Check Media Center Exit/Start Mode
13:05:14.9 2/26/2006: Media Center Mode 2
13:05:14.9 2/26/2006: Checking for applications to Launch On Startup
13:05:14.9 2/26/2006: Get other settings
13:05:14.9 2/26/2006: Using 2D Animations
13:05:15.0 2/26/2006: Set: Find emulator artwork on best match basis
13:05:15.0 2/26/2006: Launching HideOS.exe
13:05:16.0 2/26/2006: Hiding Taskbar
13:05:16.0 2/26/2006: Start work for Form
13:05:16.0 2/26/2006: Getting Original Screen Size
13:05:16.0 2/26/2006: Loading ICON
13:05:16.1 2/26/2006: Initializing Component
13:05:16.2 2/26/2006: Initialising Bass Audio Library
13:05:16.5 2/26/2006: Loading default loading screen
13:05:16.6 2/26/2006: Using General Font: Trebuchet MS
13:05:16.6 2/26/2006: Using Title Font: Trebuchet MS
13:05:16.6 2/26/2006: Initialising DirectDraw
13:05:16.6 2/26/2006: Applying GameEx is Loading Image
13:05:16.7 2/26/2006: Creating DirectDraw Device
13:05:16.7 2/26/2006: Using Device: MOBILITY M6
13:05:16.8 2/26/2006: Setting Resolution to 800x600 32 bit color
13:05:18.0 2/26/2006: Creating DirectDraw Surfaces
13:05:18.1 2/26/2006: Creating Primary Surface - Full Screen Mode
13:05:18.1 2/26/2006: Creating Back Buffer
13:05:18.1 2/26/2006: Loading graphic surfaces
13:05:18.2 2/26/2006: Creating Surfaces Misc and Dialogs
13:05:18.2 2/26/2006: Creating Surface Volume
13:05:18.3 2/26/2006: Creating Surfaces Arrows
13:05:18.3 2/26/2006: Creating Surfaces GameEXlogo Text
13:05:18.3 2/26/2006: Creating Surfaces Toolbar
13:05:18.3 2/26/2006: Creating Surfaces Backgrounds
13:05:20.0 2/26/2006: Creating Surfaces Toolbar Controls
13:05:20.0 2/26/2006: Creating Surfaces GameEx Logo
13:05:20.1 2/26/2006: Creating Surfaces Home & Exit
13:05:20.1 2/26/2006: Creating Surfaces Snaps
13:05:20.1 2/26/2006: Creating Surfaces Menu and List Bars
13:05:20.3 2/26/2006: Creating Fonts
13:05:20.3 2/26/2006: Creating Menu Font
13:05:20.5 2/26/2006: Creating Game Font
13:05:20.7 2/26/2006: Creating Game Font Standard Size
13:05:21.5 2/26/2006: Creating Font Black
13:05:21.7 2/26/2006: Creating Font Black Small
13:05:21.8 2/26/2006: Creating Game Font Faded
13:05:22.0 2/26/2006: Creating Title Font
13:05:22.3 2/26/2006: Creating Control Panel Font
13:05:23.0 2/26/2006: Fonts Created Succesfully
13:05:23.1 2/26/2006: Initialising Windows Media Player Component
13:05:23.5 2/26/2006: MAME Path is: C:\Program Files\Mame32
13:05:23.5 2/26/2006: MAME EXE file is: Mame32.exe
13:05:23.5 2/26/2006: ROM Path is: C:\Program Files\Mame32\roms
13:05:23.5 2/26/2006: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
13:05:23.5 2/26/2006: controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
13:05:23.5 2/26/2006: History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
13:05:23.5 2/26/2006: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
13:05:23.5 2/26/2006: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
13:05:23.6 2/26/2006: Loading Controls.ini map file
13:05:23.6 2/26/2006: Loading Custom Emulators
13:05:24.3 2/26/2006: Snap Path is: C:\Program Files\Mame32\snap
13:05:24.3 2/26/2006: AVI Snap Path: Not Found
13:05:24.3 2/26/2006: Flyer Path is: C:\Program Files\Mame32\flyers
13:05:24.3 2/26/2006: Cabinet Path is: C:\Program Files\Mame32\cabinets
13:05:24.3 2/26/2006: Title Path is: C:\Program Files\Mame32\titles
13:05:24.3 2/26/2006: Panel Path is: C:\Program Files\Mame32\cpanel
13:05:24.3 2/26/2006: Icon Path is: C:\Program Files\Mame32\icons
13:05:24.3 2/26/2006: Marquee Path is: C:\Program Files\Mame32\marquees
13:05:24.3 2/26/2006: MAME CMD options: -triplebuffer -nowindow -joy
13:05:24.3 2/26/2006: Attempting to load game list
13:05:24.4 2/26/2006: Loading last used Game List
13:05:24.4 2/26/2006: Setting Music Volume
13:05:24.4 2/26/2006: Creating DirectSound Device
13:05:24.4 2/26/2006: Trying: Primary Sound Driver
13:05:24.4 2/26/2006: Loading Sound Files
13:05:24.5 2/26/2006: DirectSound Device Created Successfully
13:05:24.5 2/26/2006: Creating ICONS
13:05:25.1 2/26/2006: Initialising DirectInput for Gamepad support
13:05:25.1 2/26/2006: Unable to create a joystick device
13:05:25.1 2/26/2006: Playing intro sound file
13:05:25.1 2/26/2006: Initializing MCE Remote
13:05:25.1 2/26/2006: Initialization OK! Starting GameEx!
13:05:25.1 2/26/2006: Testing Main Loop Once: Processing Frame
13:05:25.4 2/26/2006: ERRORS DETECTED: EXITING
13:05:25.4 2/26/2006: at Microsoft.DirectX.DirectDraw.Surface.DrawInternal(tagRECT* destRectangle, Surface sourceSurface, tagRECT* srcRectangle, DrawFlags flags, DrawEffects& bltEffects)
13:05:25.4 2/26/2006: at Microsoft.DirectX.DirectDraw.Surface.Draw(Rectangle destRectangle, Surface sourceSurface, Rectangle srcRectangle, DrawFlags flags)
13:05:25.4 2/26/2006: at GameEx.GameEx.mainform.DisplayFrame()
Can someone please help me with this one thanks!!
This normally occurs on systems with crappy on-board video cards.
You might be out of luck on this system, but things to try are.
- 16 Bit Colour
- Lower resolution
- Turn off Advanced graphics.
Or buy a normal video card.
I fixed it! I change my video card resolution to a lower one and presto.
I have a All-in-Wonder® X1900 256MB PCIE on my desktop and an ati mobile m6 in my labtop.
