Could anyone tell me what I am doing wrong with this chankast Setup. Here is my config:
[Emulator_41]
STARTPAGENAME=Sega Dreamcast
TITLETEXT=Dreamcast Games
StartPageLogo=
ROMFilter=*.lnk
RomsInFolders=False
RomPath=H:\Emulators\Sega_Dreamcast
SnapPath=H:\Emulators\Sega_Dreamcast\Snap
WorkingPath=H:\Emulators\Sega_Dreamcast
MapKeys=False
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=False
ShowDesktop=False
Debug=False
MAPFile=
AlsoLaunch=
Command=[ROMPath]\[RomFile]
OLDatZip=
TitlePath=H:\Emulators\Sega_Dreamcast\Title
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
configFile=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
DATABASE=
Here is my shortcut setup:
"H:\Emulators\Sega_Dreamcast\chankast_launch.exe" -fullscreen -cpu 108 -showstats -daemon "C:\Program Files\DAEMON Tools\daemon.exe" 0 "H:\Emulators\Sega_Dreamcast\iso\Super_Puzzle_Fighter_2X_for_Matching_Service_(J)(Eurasia)(SB).cdi"
I think this is where I am going wrong. The shortcut that I am creating does nothing. I am copying this info into notepad and saving it with a *.lnk prefix. Is this wrong? If not can anyone see what I have setup incorrectly.
J.
*lnk's are not text files they are shortcuts. You can right click in Explorer and select New->Shortcut from the context menu, or you can right-click and drag to "Create shortcut here". Once you have one shortcut made for "chankast_launch.exe" you can copy it and just change the appropriate parameters for each one.
Cheers HeadKaze. I still have a problem though.
I have a shortcut working (kind of). I have created a shortcut to ChanKast_launch.exe. Then right-clicked it and amended the details in the Target. This opens Chankast and attaches my image but ignores any of the command line options that I have put in. I can click on start in Chankast and the game will run but it wont autorun or start in full screen.
Any ideas what i am doing wrong now?
J.
Anyone else have this problem. It justs opens chankast (windowed and dosent autostart). All command line options are being ignored.
This is what i have in the target line of the shortcut. is there anything wrong with this:
H:\Emulators\Sega_Dreamcast\chankast_launch.exe -screen 1024x768 -fullscreen -cpu 108 -daemon "C:\Program Files\Daemon Tools\daemon.exe" 0 "C:\Documents and Settings\Dave\My Documents\BORDER_DOWN.mds"
Any help would be much apprieciated
J.
