I uninstalled then reinstalled the program to start fresh, but after reinstalling, the configuration setup was the same as the original installation.
How do I clear out the old config setting in order to have the same setting as if I were installing the program for the first time?
Jerry
If you are not concerned with keeping any of your previous configuration, you can simply delete the GameEx folder which will delete everything within. Then install directly from the downloaded installer.
