[RESOLVED] Help on How to stop Mame Mapping Magician.exe from poping up
Okay every darn time I start the GameEx.exe this annoying window up every time . I like it to fully completely stop from poping up evertime the GameEX.exe start up
This dam window keep driving me nuts from poping up..to be honest this window should never come to play within the GameEx software <_< so please help me get rid of it or show me in the option on how to get rid this annnoying window called Mame Mapping Magician.exe I posted my log.txt to show you this thing come up everytime I start GameEx
Hi JCGamer!
It might be more informative to take a look at your GameEx.ini, but I can say definitively that this doesn't look right:
08:08:18.0 2/7/2013: MAME EXE file is: Mame Mapping Magician.exe
Double check your MAME settings and make sure you're pointed at the correct MAME executable.
Yeah, you'll want to fix this if you haven't already:
It's on the MAME Settings screen.
Good luck man!
Null you are the MAN that did the trick OMG I see why you a moderator.thank for everything its running good ^_^ .
but please just tell me :mellow: what in god name would the program made to be */GameEX on Mame path and the exe path on Mame Mapping Magician.exe. I remember back in 2007 when I was using the older verison GameEX never had that problem till you point that out for me.
Awesome! I'm glad to hear you got it sorted out JCGamer. Could have been a hiccup with the ini, or maybe something was inadvertently altered in your settings at some point. All's well that ends well. :)
Happy gaming!
Happy gaming!
thanks man but now got to deal with is Sega Genesis and Playstation emulator.Just hope and pray nothing goes wrong with them
Edited by nullPointer
This topic has been marked as RESOLVED and is now closed. Please begin a new thread if you are experiencing any similar issues
