Hi guys.
i want to create a clean menu system.
How do I remove the | Change View | Back | Home | Exit | header from my list? Do I do it in the Theme editor or is there a setting in the configuration for that?
Hey,
Welcome to the forums,
I find the easiest method to do this is to open up the theme your using in the theme editor and click on the theme piece called menu and look at the X or Y axis on the left hand side and change to 2000 this will remove the menu from your theme providing your not using custom layout/custom emulator layouts. This method should remove the options entirely.
There are also options in the enable/disable features section in the setup wizard to hide change view etc.. , which you may find more beneficial.
