Hello,
I just bought Game Ex and subscribe for life with emumovies.com
I've got a question concerning the system-intro video.
Question number 1 :
I downloaded many system_intro files ( master system, mame, super nes etc..)
After many search, I finally found where to put those files, with the help of Draco1962 that has give an answer in another thread.
I still have one question.
The actual solution is to put the *.mp4 video under the directory "\\gameex\themes\THEME NAME HERE\MEDIA\Database" or somehting like that.
We just have to take the logo jpeg name ( for exemple snes_intro.jpg) and rename the video with the same name : (snes_intro.mp4)
With this solution, the logo is remplaced by the system intro video.
But, when i'm doing this thing, I loose the Jpeg Logo. Is there a way to have both ? ( The Logo, AND the system intro video ?)
If not, thise feature would be perfect.
Question number 2 :
When i'm under the classic theme , all the video snap are played under the roms Pics or atrwok.
The video is played in a little square. Is there a way to have this video played in a bigger square ?
The video is played very down in the screen. it "touch" the back of the theme. Is there a way to make it more high ?
Sorry for my bad english, I hope that you can understand what I mean.
Hope someone can help
regards
Sylvain
Sorry there has been no immediate response to your queries.
Question number 1 :
Unfortunately, you cannot have it both ways with regards to the video or still image for the same system or feature - It's one or the other.
Question number 2 :
First, no need to apologize - you are understood! Second, it would require that you modify the image size via Theme Editor and save the changes. Keep in mind that some themes will have foreground files to compliment the background images of the themes and these, too, may need to be modified to allow for any size changes to the image sizes. If you are unfamiliar or uncomfortable making these changes, you may have to select another theme or create one yourself that fits your needs.
