After my initial schooling :) on setting up MAME I've been working no stop over the last 3 days to add more and more into GameEx with 100% success. My kids saw the Karaoke option so I figured I'd please them and configure it, so.....
1) I did not install the Karaoke option when I initally installed GameEx. Is it just a matter of rerunning the install and selecting that option?
2) If I do rerun the install does it write over the config files? (After 3 days, I would hate to recreate them)
3) I see old posts about the Karaoke software not being the best, any recommendations for an external program?
4) I quickly set up gameex on a test box and I see the 2-3 karaoke songs and it plays a snipet if i highlight over it, but when I click on the song it goes black and right back to the gameex screen.
Z
GameEx.ini
Mine is working fine. Had the same problems several updates ago and I updated my codecs to the latest shark codec and it works fine. Also check and make sure ypu are running the latest directx
