I must be missing something. I've added several radio stations to favorites but I can't find the favorites list. I've checked the wizard, but I can only find the favorites for MAME to enable but that's it.
Can anyone point me in the right direction? Thanks.
You should see Favorites listed in the menu bar (same place you select Genre, etc.). You will see them there.
Ignore my last post. I see where it should be, but all I can see is the icon of the radio on the left side. I must have disabled it somehow, I just need to find where I did that.
You might want to provide me with a copy of your log.txt and gameex.ini file so I can assist you. Please refer to this link for additional information if you are unsure where to locate them.
