Hi,
I have a problem with games manuals reading in Gameex. This just do not work and instad its the video preview of the game showing.
I have installed the Ghostscript package but it does not work. It is also not very clear for me in which directory the package should be unpacked?
I am running the latest version of gameex on XP32 bit. I read also that at the key registry prompt I must allow only the 32bit key to be copied in the registry. TRied it but it does not work.
Please help... <_<
Rick
When reporting a possible GameEx bug or error, please ensure you submit a copy of your log.txt and gameex.ini file so we may quickly assist you. Please refer to this link for additional information.
Ok I figured it out!
Opened a log and it said the PDF viewer could not be found. The path gameex was expecting was different from the one I have on the HD. I changed it now it matches and working!
Thanks a lot for your help! :P
Edited by nullPointer
This topic has been marked as RESOLVED and is now closed. Please begin a new thread if you are experiencing any similar issues.
