I recently downloaded Nestopia from GameEx Set-Up Screen and when i try to run the program it says "The Program cannot start because d3dx9_43.dll is missing from your computer. Try reinstalling the program to fix this problem."
Now i tried reinstalling and that did nothing. I also tried running the program outside of GameEx and it comes up with the same message. HELP!
This DLL isn't included in new DirectX packs. You need to do a Google search for d3dx9_43.dll and put it in Windows > System32 folder.
Same thing for pSX although I think its a different DLL (d3dx9_41.DLL I think?).
Are you sure about that? I've never downloaded any additional files and I have those files in my directory. I wouldn't suggest downloading the dll's on their own unless from a reliable source.
Yeah I'm sure.
I snagged the DLL off my XP machine when I installed Nestopia's unofficial build on the sourceforge page. My cab doesn't have dx9 and that's a 9 DLL.
