ccs64 emulator not working with GameEx
Guest penfold31
Hi,
I'm currently trying to set-up the commodore 64 emulator ccs64 through GameEx but are having problems doing so. I've already got ccs64 setup and working on it's own and have played game on it with the controls configured for my game-pad. The roms are loaded into GameEx along with some auto downloaded artwork, but when i click to play a game GameEx just closes and then re-opens again a few seconds later.
Hope someone can help.
Emulator config
[Emulator]
CDCheckFile=
CDCheck=False
RandomMostPlayed=True
ShowMostPlayed=True
PlayInScreenSaver=False
GamesIn7Zips=False
PCGame=False
SelectionMusicFolder=
PlaySelectionMusic=False
DontShowInfo=
PlayMusic=False
CustomBackground=
ExcludedFiles=
LaunchAfter=
LaunchBefore=
OLDatZip=
AlsoLaunch=
Debug=False
ShowDesktop=True
RemoveBrackets=True
Capitals=False
ReplaceUnder=True
ReplaceDash=False
SendKeys=
WaitBeforeKeys=
MapKeys=True
WorkingPath=C:\Users\Lee\Documents\EmulatorsAndRoms\Emulators\CCS64
ControlPanelPath=C:\Users\Lee\Documents\EmulatorsAndRoms\Assets\Commodore 64\Controls
ManualPath=C:\Users\Lee\Documents\EmulatorsAndRoms\Assets\Commodore 64\Manuals
CartPath=C:\Users\Lee\Documents\EmulatorsAndRoms\Assets\Commodore 64\Cartridges
BoxPath=C:\Users\Lee\Documents\EmulatorsAndRoms\Assets\Commodore 64\Boxes
TitlePath=C:\Users\Lee\Documents\EmulatorsAndRoms\Assets\Commodore 64\Titles
SnapPath=C:\Users\Lee\Documents\EmulatorsAndRoms\Assets\Commodore 64\Snaps
RomPath=C:\Users\Lee\Documents\EmulatorsAndRoms\Roms\Commodore 64\Roms
MapFile=
ConfigFile=[Mapping Off] Exit (Process Close)
Database=[PC] Commodore 64
RomFilter=
Command=CCS.exe "[ROMPATH]\[ROMFILE]" -window -autorun
StartPageLogo=Commodore
StartPageName=[PC] Commodore 64 (CCS64)
TitleText=Commodore 64
Info=Commodore 64 Emulator
Website=http://www.ccs64.com/
RequiredFiles=
DownloadUrl=http://www.gamesdbase.com/setupwizard/emulators/download/CCS64.7z
Rating=7.5
Version=3.8
Emulator=CCS64
Category=PC
System=Commodore 64
Run last game
chcp 65001
C:
CD "C:\Users\Lee\Documents\EmulatorsAndRoms\Emulators\CCS64"
CCS.exe "C:\Users\Lee\Documents\EmulatorsAndRoms\Roms\Commodore 64\Roms\Akropolis (203).zip" -window -autorun
log gameex.txt
GameEx ini.txt
If you are using zip files on an emulator that does not handle zip files, you need to set GamesIn7Zips=False to true. I did do a config a while ago that unzip files for you (this also had the benefit when using gamebase that the other discs were unzipped and ready). Since then, GameEx added support natively.
Or, In Setup Wizard, Advanced Emulator Setup, set "Zip/7-Zip/GoodMerge" to True (if that is easier)
Also, make sure your zips contain nothing other than the rom files, if this is not the case, remember to set your rom filter to match the file within the zip (ie. *.d64)
One thing to mention is that Zip/7-Zip/GoodMerge support is available only if you have purchased a 1 year or Lifetime subscription to GameEx. Besides enabling Zip/7-Zip/GoodMerge support, you have a host of other useful features that you may be interested. More about these features can be found here.
