Sorry to hear you are having trouble. I'm afraid there is not much we can do to help without a lot more detail. Specifically, what is the plugin's name? How do you have it configured? What emulator(s) are impacted.
When reporting a possible GameEx bug or error, please ensure you submit a copy of your log.txt and gameex.ini file so we may quickly assist you. Please refer to this link for additional information.
Again, will be glad to try to assist but you must provide the files that have been requested. Click this link if you need assistance in finding the requested files. Not much else we can do to to assist you without them. Sorry.
20:02:55.2 11/2/2012: Opening Configuration File
20:02:55.2 11/2/2012: GameEx: Version 12.85: Starting Log
20:02:55.2 11/2/2012: Operating System Platform: Win32NT
20:02:55.2 11/2/2012: Operating System Name: Windows 7
20:02:55.2 11/2/2012: Operating System Version: 6.1.7601
20:02:55.2 11/2/2012: Aero NOT running
20:02:55.2 11/2/2012: Initializing Vista/Windows 7 volume control
20:02:55.2 11/2/2012: Getting CPU and RAM info
20:02:55.3 11/2/2012: AMD Phenom™ II X6 1090T Processor, 3838MB
20:02:55.3 11/2/2012: 3.21Ghz - 6 Cores or CPU's
20:02:55.3 11/2/2012: Running Randomize()
20:02:55.4 11/2/2012: Loading PlugIns
20:02:55.5 11/2/2012: Loaded Plugin:"LCD/LED Plugin" Version 2.87 By Ben Baker
20:03:02.5 11/2/2012: PlugIn: "LCD/LED Plugin" Initialized OK
20:03:02.6 11/2/2012: Using Plugin System Version: 1.3
20:03:02.6 11/2/2012: Checking for applications to Launch On Startup
20:03:02.6 11/2/2012: Running Misc startup tasks
20:03:02.6 11/2/2012: Setting Menu types
20:03:02.6 11/2/2012: Getting Configuration Values
20:03:02.6 11/2/2012: Using Theme: Default - RedEx - MCE1024x768
20:03:02.6 11/2/2012: Checking for alternate Image Directory for Theme: Default - RedEx - MCE1024x768
20:03:02.6 11/2/2012: Launching HideOS.exe
20:03:02.6 11/2/2012: Initialising Video/MNG DLL's
20:03:02.6 11/2/2012: GameEx will check for media insertion (may affect performance)
20:03:02.6 11/2/2012: Hiding Taskbar
20:03:02.7 11/2/2012: Is Media Center running?
20:03:02.7 11/2/2012: Checking/Creating LCD Registry values
20:03:02.7 11/2/2012: Check Media Center Exit/Start Mode
20:03:02.7 11/2/2012: Media Center Mode 2
20:03:02.7 11/2/2012: Video previews on. Warning: Only recommended on modern systems
20:03:02.7 11/2/2012: Snap Delay set to: 2
20:03:02.7 11/2/2012: Get other settings
20:03:02.7 11/2/2012: Desktop set to Hide ICONS and set Background to Black
20:03:02.7 11/2/2012: Set: Find emulator artwork on best match basis
20:03:02.7 11/2/2012: Start work for Form
20:03:02.7 11/2/2012: Getting Original Screen Size
20:03:02.7 11/2/2012: Opening Database Connection
20:03:03.3 11/2/2012: Initializing Component
20:03:03.4 11/2/2012: MAME Path is: C:\Users\Arcade\Desktop\New Folder (2)\MAME
20:03:03.4 11/2/2012: MAME EXE file is: mame.exe
20:03:03.4 11/2/2012: ROM Path is: E:\emu\MameUI32\roms
20:03:03.4 11/2/2012: Catver.ini is located at: C:\GameEx\DATA\catver.ini
20:03:03.4 11/2/2012: controls.ini is located at: C:\GameEx\DATA\controls.ini
20:03:03.6 11/2/2012: History.dat is located at: C:\GameEx\DATA\history.dat
20:03:03.6 11/2/2012: nplayers.ini is located at: C:\GameEx\DATA\nplayers.ini
20:03:03.6 11/2/2012: command.dat is located at: C:\GameEx\DATA\command.dat
20:03:03.6 11/2/2012: MAMEinfo.dat is located at: C:\GameEx\DATA\mameinfo.dat
20:03:03.6 11/2/2012: Loading Controls.ini map file
20:03:03.6 11/2/2012: Snap Path is: C:\Users\Arcade\Desktop\New Folder (2)\MAME
20:03:03.6 11/2/2012: Background Snap Path: Not Found
20:03:03.6 11/2/2012: AVI Snap Path is: C:\GameEx\DEMO\MAME\video
20:03:03.6 11/2/2012: Flyer Path is: C:\Users\Arcade\Desktop\New Folder (2)\MAME
20:03:03.6 11/2/2012: Cabinet Path is: C:\Users\Arcade\Desktop\New Folder (2)\MAME
20:03:03.6 11/2/2012: Cabinet 3D Path is: C:\GameEx\DEMO\MAME\cabinets3d
20:03:03.6 11/2/2012: Title Path is: C:\Users\Arcade\Desktop\New Folder (2)\MAME itles
20:03:03.6 11/2/2012: PCB Path: Not Found
20:03:03.6 11/2/2012: Artwork Preview Path: Not Found
20:03:03.6 11/2/2012: Panel Path is: C:\Users\Arcade\Desktop\New Folder (2)\MAME
20:03:03.6 11/2/2012: Manual Path is: C:\Users\Arcade\Desktop\New Folder (2)\MAME\manuals
20:03:03.6 11/2/2012: Icon Path is: C:\Users\Arcade\Desktop\New Folder (2)\MAME
20:03:03.6 11/2/2012: Marquee Path is: C:\Users\Arcade\Desktop\New Folder (2)\MAME
20:03:03.6 11/2/2012: Applying Language/Text
20:03:03.6 11/2/2012: Text/Language: English
20:03:03.6 11/2/2012: Loading Language/Text
20:03:03.6 11/2/2012: Loading Custom Emulators
20:03:03.6 11/2/2012: Loading Emulator 1: [Arcade] Arcade (MAME)
20:03:03.6 11/2/2012: Checking if Steam enabled
20:03:03.6 11/2/2012: Cannot find steam path
20:03:03.6 11/2/2012: Using 2D Animations
20:03:03.6 11/2/2012: Retrieving resolution setting
20:03:03.6 11/2/2012: Using General Font: Trebuchet MS
20:03:03.6 11/2/2012: Using Title Font: Trebuchet MS
20:03:03.6 11/2/2012: GameEx will try to reduce CPU usage
20:03:03.7 11/2/2012: Initialising Direct3D
20:03:03.9 11/2/2012: Applying GameEx is Loading Image
20:03:03.9 11/2/2012: Setting Resolution to 1024x768 32 bit color
20:03:03.9 11/2/2012: Creating Surfaces
20:03:04.2 11/2/2012: Creating Primary Surface - Full Screen Mode
20:03:04.2 11/2/2012: Creating Back Buffer
20:03:04.2 11/2/2012: Loading graphic Surfaces
20:03:04.2 11/2/2012: Display is running at: 1024x768 32bit color, 60hz
20:03:04.2 11/2/2012: Adapter: ATI Radeon HD 4290
20:03:04.2 11/2/2012: Max texture size: 8192x8192
20:03:04.2 11/2/2012: Available texture memory: 2009MB
20:03:04.3 11/2/2012: Initialising Bass Audio Library
20:03:04.3 11/2/2012: Creating Surfaces Misc and Dialogs
20:03:04.6 11/2/2012: Creating Surfaces Volume
20:03:04.6 11/2/2012: Creating Surfaces Arrows
20:03:04.7 11/2/2012: Creating Surfaces GameEXlogo Text
20:03:04.7 11/2/2012: Creating Surfaces Toolbar
20:03:04.8 11/2/2012: Creating Surfaces Toolbar Controls
20:03:04.8 11/2/2012: Creating Surfaces Backgrounds
20:03:04.8 11/2/2012: Creating Surfaces GameEx Logo
20:03:04.8 11/2/2012: Creating Surface Unselected
20:03:04.8 11/2/2012: Creating Surfaces Home & Exit
20:03:04.8 11/2/2012: Creating Surfaces Snaps
20:03:04.8 11/2/2012: Creating Surfaces Menu and List Bars
20:03:04.9 11/2/2012: Creating Fonts
20:03:04.9 11/2/2012: Creating Game Font
20:03:05.3 11/2/2012: Creating Game Font Faded
20:03:05.3 11/2/2012: Creating Title Font
20:03:05.3 11/2/2012: Restoring Title Font From Cache
20:03:05.5 11/2/2012: Creating Menu Font
20:03:05.6 11/2/2012: Creating Font Black
20:03:05.7 11/2/2012: Creating Font Black Small
20:03:05.7 11/2/2012: Fonts Created Succesfully
20:03:05.7 11/2/2012: 3MB Video Memory Used
20:03:05.9 11/2/2012: Attempting to load game list
20:03:06.1 11/2/2012: Running: mame.exe -help
20:03:06.2 11/2/2012: Running: C: C:\Users\Arcade\Desktop\New Folder (2)\MAME\mame.exe -help > C:\Users\Arcade\Desktop\New Folder (2)\MAME\help.txt
20:03:06.5 11/2/2012:
20:03:06.5 11/2/2012: Detected MAME Version as: 0.145
20:03:06.5 11/2/2012: 32 bit MAME version detected on 64 bit windows
20:03:06.5 11/2/2012: Now Outputing mame.exe -Help
20:03:06.5 11/2/2012: --BEGIN--
20:03:06.5 11/2/2012: M.A.M.E. v0.145 (Feb 5 2012) - Multiple Arcade Machine Emulator
20:03:06.5 11/2/2012: Copyright Nicola Salmoria and the MAME team
20:03:06.5 11/2/2012: MAME is an emulator: it reproduces, more or less faithfully, the behaviour of
20:03:06.5 11/2/2012: several arcade machines. But hardware is useless without software, so an image
20:03:06.5 11/2/2012: of the ROMs which run on that hardware is required. Such ROMs, like any other
20:03:06.5 11/2/2012: commercial software, are copyrighted material and it is therefore illegal to
20:03:06.5 11/2/2012: use them if you don't own the original arcade machine. Needless to say, ROMs
20:03:06.5 11/2/2012: are not distributed together with MAME. Distribution of MAME together with ROM
20:03:06.5 11/2/2012: images is a violation of copyright law and should be promptly reported to the
20:03:06.5 11/2/2012: authors so that appropriate legal action can be taken.
20:03:06.5 11/2/2012: Usage: MAME [game] [options]
20:03:06.5 11/2/2012: MAME -showusage for a brief list of options
20:03:06.5 11/2/2012: MAME -showconfig for a list of configuration options
20:03:06.5 11/2/2012: MAME -listmedia for a full list of supported media
20:03:06.5 11/2/2012: MAME -createconfig to create a mame.ini
20:03:06.5 11/2/2012: For usage instructions, please consult the files config.txt and windows.txt.
20:03:06.5 11/2/2012: --END--
20:03:06.5 11/2/2012: MAME CMD options: -nowindow -joy -skip_gameinfo
20:03:06.5 11/2/2012: Initialising DirectInput for Gamepad support
20:03:06.6 11/2/2012: Unable to create a joystick device
20:03:06.6 11/2/2012: Loading Start Page
20:03:06.6 11/2/2012: Initializing MCE Remote
20:03:06.7 11/2/2012: Playing intro sound file
20:03:06.7 11/2/2012: Initialization OK! Starting GameEx!
20:03:06.7 11/2/2012: Testing Main Loop Once: Processing Frame
20:03:07.3 11/2/2012: Testing Main Loop Once: Main Loop ran successfully
20:03:17.0 11/2/2012: Writing Game List to disk
20:03:17.1 11/2/2012: Updating MAME Game List
20:03:17.1 11/2/2012: Running: C: C:\Users\Arcade\Desktop\New Folder (2)\MAME\mame.exe -listxml > C:\Users\Arcade\Desktop\New Folder (2)\MAME\listinfo.dat
20:03:53.7 11/2/2012: Opening Listinfo.dat
20:03:55.2 11/2/2012: Reading ListInfo.dat
20:04:03.1 11/2/2012: Reading ListInfo.dat - DONE
20:04:03.1 11/2/2012: Running: C: C:\Users\Arcade\Desktop\New Folder (2)\MAME\mame.exe -verifysets -rompath "E:\emu\MameUI32\roms" > C:\Users\Arcade\Desktop\New Folder (2)\MAME\verify.dat
20:05:54.3 11/2/2012: Opening Verify.dat
20:05:55.3 11/2/2012: Processing Verify.dat
20:05:55.4 11/2/2012: Total verifyable roms: 18653
20:05:55.4 11/2/2012: Processing ListInfo.dat
20:05:57.0 11/2/2012: Listinfo.dat Processing Complete
20:05:57.0 11/2/2012: Sorting MAME Game List
20:05:57.2 11/2/2012: Adding Catver.ini info to gamelist
20:06:00.9 11/2/2012: Importing MAME32 Favorites
20:06:00.9 11/2/2012: Updating Custom Folders
20:06:00.9 11/2/2012: Writing MAME Game List To File
20:06:14.5 11/2/2012: Writing MAME Game List To File
20:06:17.6 11/2/2012: Adding History.dat info to gamelist
20:06:18.7 11/2/2012: Adding History.dat Series info to gamelist
20:07:20.1 11/2/2012: Adding MAMEInfo.dat info to gamelist
20:08:07.8 11/2/2012: Adding Nplayers.ini info to gamelist
20:08:08.6 11/2/2012: Writing Game List to disk
20:08:08.9 11/2/2012: Updating Year List
20:08:08.9 11/2/2012: Updating Manufacturer List
20:08:08.9 11/2/2012: Updating Category List
20:08:09.0 11/2/2012: Writing Year List To File
20:08:09.0 11/2/2012: Writing Manufacturer List To File
20:08:09.0 11/2/2012: Writing Category List To File
20:08:09.0 11/2/2012: Loading Game List
20:08:09.1 11/2/2012: Creating: [Arcade] MAME.mdb
20:08:11.4 11/2/2012: Recreating ICONS
20:08:11.7 11/2/2012: Attract Mode Re-Enabled
20:10:58.0 11/2/2012: Exiting GameEx!
20:10:58.0 11/2/2012: Disposing all videos
20:10:58.0 11/2/2012: Deleting temporary Karaoke videos
20:10:58.0 11/2/2012: Disposing Image List
20:10:58.0 11/2/2012: Disposing Fonts
20:10:58.0 11/2/2012: Disposing Surfaces
20:10:58.0 11/2/2012: Saving Settings
20:10:58.0 11/2/2012: Shutting down Bass
20:10:58.1 11/2/2012: Closing HideOS.exe
20:10:58.4 11/2/2012: Disposing Plugins
20:10:58.4 11/2/2012: Closing database connection
20:10:58.4 11/2/2012: Checking for applications to Launch On Exit
20:10:58.4 11/2/2012: Media Center was not open when starting GameEx, so not launching
20:10:58.4 11/2/2012: Bye
A[General]
Xresolution=800
Yresolution=600
DisplayOnSecondary=False
mamepath=C:\Users\Arcade\Desktop\New Folder (2)\MAME
mameexe=mame.exe
rompath=E:\emu\MameUI32\roms
StartWait=False
USeAdvanceMame=False
AdvanceMAMEEXE=advmame.exe
AdvanceMAMEPATH=C:\Emulators\AdvanceMAME
ADVANCEMAMEOptions=-device_video_output fullscreen -quiet -dir_rom "C:\Emulators\Mame32\roms"
UseZinc=False
ZincEXE=zinc.exe
ZincPATH=C:\Emulators\ZiNc
ZincOptions=--renderer=.\renderer.znc
Font=Trebuchet MS
TitleText=MAME Games
OnlyWorking=True
AllowImperfect=True
VerifyRoms=True
OnlyRoms=False
NoGameInfo=False
GameFilter=Japan;Korea;Asia;Hispanic;Bootleg;French;German;Hack;Prototype;Hardware;Spanish;(Easy;(harder
GameFilterOn=True
NoAdult=False
NoClones=1
MameOptions=-nowindow -joy -skip_gameinfo
ArcadeMode=False
UseLargeFonts=True
snappath=C:\Users\Arcade\Desktop\New Folder (2)\MAME
avisnappath=C:\GameEx\DEMO\MAME\video
AVIFrameSkip=0
flyerpath=C:\Users\Arcade\Desktop\New Folder (2)\MAME
cabinetpath=C:\Users\Arcade\Desktop\New Folder (2)\MAME
CatverLocation=\DATA\catver.ini
nplayerslocation=\DATA\nplayers.ini
HistoryLocation=\DATA\history.dat
InfoLocation=\DATA\mameinfo.dat
CommandLocation=\DATA\command.dat
ShowGameInfoPage=True
EnableStartPage=True
ShowStartPageFirst=True
skipintro=False
AntiAliasFonts=True
OutlineFonts=False
DisplayBackgroundImage=True
SnapBrightness=120
MusicPlayList=C:\Music
MusicVolume=100
MediaCenterMode=2
PlayIntroSound=True
AttractModeTimer=4
AttractModeAudio=2
UsingArcadeVGA=False
StretchResToX=640
StretchResToY=288
TryToStretchto256=True
NoWaitVSync=False
Sleep=True
HideUpdateList=False
DisableExit=False
HideShutDown=False
StartUpVideo=C:\Video
LaunchOnStart=
LaunchOnStartNoWait=
LaunchOnExit=
LaunchOnExitNoWait=
FontSize=0
VectorResX=632
VectorResY=264
AlwaysStretch=410x256
DisableEscape=False
DisableRemoveGame=False
theme=Default - RedEx - MCE1024x768
Language=English
FlatStartPage=False
DontSwitchRes=True
SnapDelay=2
AllowWindowResize=True
ShowLoadingScreen=True
Use16BitColour=False
Widescreen=False
DisableMAME=False
ShellBeforeLaunch=
ShellOnExit=
EnableJukeBox=True
jukeboxplaylist=Live! (CD1)
EnableMediaControls=True
ShufflePlayLists=True
LoadPlayListAtStartup=False
LoadPlayListThread=False
DownloadArt=True
TitleFont=Trebuchet MS
DialogTextWhite=False
TimeFormat=True
HideToolBar=3
DoNotFilterROMS=pacman;splatter
MAMEAudioMode=1
DisplayTitle=True
AVIAudio=True
marqueepath=C:\Users\Arcade\Desktop\New Folder (2)\MAME
panelpath=C:\Users\Arcade\Desktop\New Folder (2)\MAME
titlepath=C:\Users\Arcade\Desktop\New Folder (2)\MAME itles
iconpath=C:\Users\Arcade\Desktop\New Folder (2)\MAME
CPEnabled=True
CPPATH=\DATA\controls.ini
ShowVector=True
ShowNeoGeo=True
ShowOriginal=True
ShowAdult=True
ShowCPS=True
ShowVertical=True
ShowHorizontal=True
EnableFavorites=True
ShowMulti=True
ShowAllMAME=True
ShowLastGame=True
ShowRandomGame=True
ShowListNumbers=True
AlphaBlendVideos=True
EnableSound=True
MediaCenterOpenCheck=true
UseSharp=True
CreateImageOnThread=False
HideCreateSnaps=False
HideLogoff=False
HideStandBy=False
DisableMouse=False
ShowVideos=True
VideoPath=
EnableAlphaPage=True
EnableJoystick=True
EnableSlikStik=False
KeyboardDirectInput=False
NoMahjong=True
VIDEOFFDSHOW=0
JoystickDevice=
EnableCustomInput=False
EnableCustomJoyInput=False
AttractVideosEnabled=True
attractvideosratio=-1
attractvideospath=C:\GameEx\DEMO\Videos
AtractModeNewGameTimer=2
AdvancedGFX=True
HideZinc=False
TransitionType=0
Bypass=True
DontBlitWait=False
ShowMostPlayed=True
ExcludedMAMERoms=
DeadZoneX=0
DeadZoneY=0
JukeBoxMode=0
EnableAmbiance=True
HIDEDESKTOP=True
UseSnapBestMatch=true
IngameVK=121
EnableThemePicker=True
DisablePleaseWaitAnimation=False
EnableRipCD=True
DumbyValue=
DVDPath=G:\
AttractOnlyFavs=False
rotateplus90=False
ShowButtons=True
DisplayTitleText=True
PlayExitSaverSound=False
ShowAtari=True
ShowGolden=True
ShowHorizVert=0
UseModel2=False
Model2PATH=C:\Emulators\Model2
ShowModel2=True
ShowLightGun=True
EnableBezel=False
AutoUpdate=1
NoMAMEOnStartPage=False
HideRestart=False
EnableStartScreenSaver=True
SortMAMEThE=True
SortEmuThE=True
ShowMCEEXport=True
NoRotationRestrictions=False
MakeToolbarTextWhite=False
ExitGameAfter=0
ShowTrackball=True
ShowSpinner=True
LoadEmusOnThread=True
LoadRadioOnThread=False
StartPageAni=True
EmusAttractMode=False
MuteEmuAttractMode=False
Show4Player=True
CabControlFriendly=False
manualpath=C:\Users\Arcade\Desktop\New Folder (2)\MAME\manuals
HideShowTaskbar=True
CustomMAMEFolderPath=C:\Emulators\Mame32\CustomFolders
MAMEFavoritesini=C:\Emulators\Mame32\Folders\Favorites.ini
MenuFontSameSize=False
PreviewVideos=2
ShowStatistics=True
DisableMouseWheel=False
ErrorReporting=0
ReduceCPU=True
ShowNotPlayed=True
ShowOnlineLists=True
ScreensaverMode=0
AttractText=Touch screen to start...
GlaunchEnabled=False
PCBPath=C:\Emulators\Mame32\pcb
ArtworkPath=C:\Emulators\Mame32\artworkpreview
LoadJukeTracksOnStartup=True
EnableLetterSelect=True
JukeQueueMode=0
EnableBezelAttract=True
ForceDailyReboot=-1
EnableSearch=True
FixToEmuList=0
ShowLastPlayed=True
TwoThreeRes=
EnableTouchScreen=True
EnableMediaCheck=True
EnableOtherSystems=True
ForceShutdown=False
EnableHiScore=True
DisplayImageList=False
SortEmulators=True
ShowAllGames=True
InactivityTimer=0
EnableAdvCustomInput=False
HideHibernate=False
EnableKeyboardShutdown=False
AutoRotateMAME=False
EnableLaunchDialog=True
lastmusicpath=G:\-DATA-\-MP3-
looplist=False
TrackballSupport=False
EnableVisualizations=True
EnableVideoThumbs=False
cabinet3dpath=C:\GameEx\DEMO\MAME\cabinets3d
EnableClientServerMAME=False
ClientServerMAMEPath=C:\Emulators\ClientServerMAME
ClientServerMAMEEXE=vmame.exe
OnQueueEndMode=0
MAMERemoveDupes=2
CommnadLocation=\DATA\command.dat
AutoDownloadDescriptions=True
GameExtenderCustomImageMAMEPath=C:\Emulators\Mame32\marquees
Enablepopupdescriptions=True
SetPalRes=False
PalRes=800x600x32x60
SetNTCSRes=True
NTSCRes=800x600x32x60
SetNTSCRes=False
SetTwoThreeRes=False
AmbianceFolder=C:\ProgramData
EnableEscapeKeyExit=True
DisableChangeView=False
EnabledConfigurationApp=True
ResumeLastAtStartup=False
HelpText=
ShowHistoryAndMAMEInfo=True
baksnappath=C:\Emulators\Mame32\backgroundsnap
TVVideoPath=
othervideopath=C:\GameEx\DEMO\Videos;C:\Video;[myvideos]
ChangeMonitorFrequency=False
ChangeMonitorResolution=False
NoCasino=False
EnableDownloadService=True
demoinstalledversion=1
[Daphne]
UseDaphne=False
DaphnePath=C:\Emulators\Daphne
DaphneExe=Daphne.exe
DaphneSnap=C:\Emulators\Daphne\images
DaphneOptions=vldp -fullscreen -x 640 -y 480 -nohwaccel
Enabled_1=True
ROMName_1=astron
GameName_1=Astron Belt
GameOptions_1=-framefile "C:\Roms\Laserdisc\Astron Belt\astron.txt"
Enabled_2=True
ROMName_2=badlands
GameName_2=Badlands
GameOptions_2=-framefile "C:\Roms\Laserdisc\Badlands\badlands-r.txt"
Enabled_3=True
ROMName_3=bega
GameName_3=Bega's Battle
GameOptions_3=-framefile "C:\Roms\Laserdisc\Bega's Battle\bega.txt"
Enabled_4=True
ROMName_4=cliff
GameName_4=Cliff Hanger
GameOptions_4=-framefile "C:\Roms\Laserdisc\Cliff Hanger\cliff-r.txt"
Enabled_5=True
ROMName_5=cobraab
GameName_5=Cobra Command
GameOptions_5=-framefile "C:\Roms\Laserdisc\Cobra Command\cc_framefile.txt
Enabled_6=True
ROMName_6=lair
GameName_6=Dragon's Lair
GameOptions_6=-framefile "C:\Roms\Laserdisc\Dragon's Lair\dl_framefile.txt"
Enabled_7=True
ROMName_7=lair2
GameName_7=Dragon's Lair II Timewarp
GameOptions_7=-framefile "C:\Roms\Laserdisc\Dragon's Lair II Timewarp\DL2_single_framefile.txt"
Enabled_8=True
ROMName_8=esh
GameName_8=Esh's Aurunmilla
GameOptions_8=-framefile "C:\Roms\Laserdisc\Esh's Aurunmilla\esh.txt"
Enabled_9=True
ROMName_9=firefox
GameName_9=Firefox
GameOptions_9=-framefile "C:\Roms\Laserdisc\Firefox\firefox.txt"
Enabled_10=True
ROMName_10=ffr
GameName_10=Freedom Fighter
GameOptions_10=-framefile "C:\Roms\Laserdisc\Freedom Fighter\ffr.txt"
Enabled_11=True
ROMName_11=galaxy
GameName_11=Galaxy Ranger
GameOptions_11=-framefile "C:\Roms\Laserdisc\Galaxy Ranger\galaxy-r.txt"
Enabled_12=True
ROMName_12=gtg
GameName_12=Goal to Go
GameOptions_12=-framefile "C:\Roms\Laserdisc\Goal to Go\gtg.txt"
Enabled_13=True
ROMName_13=interstellar
GameName_13=Interstellar Laser Fantasy
GameOptions_13=-framefile "C:\Roms\Laserdisc\Interstellar Laser Fantasy\interstellar.txt"
Enabled_14=True
ROMName_14=lgp
GameName_14=Laser GP
GameOptions_14=-framefile "C:\Roms\Laserdisc\Laser GP\lasergp.txt"
Enabled_15=True
ROMName_15=mach3
GameName_15=Mach 3
GameOptions_15=-framefile "C:\Roms\Laserdisc\Mach 3\mach3.txt"
Enabled_16=True
ROMName_16=roadblaster
GameName_16=Road Blaster
GameOptions_16=-framefile "C:\Roms\Laserdisc\Road Blaster\roadblaster.txt"
Enabled_17=True
ROMName_17=ace
GameName_17=Space Ace
GameOptions_17=-framefile "C:\Roms\Laserdisc\Space Ace\ace.txt"
Enabled_18=True
ROMName_18=sdq
GameName_18=Super Don Quix-ote
GameOptions_18=-framefile "C:\Roms\Laserdisc\Super Don Quix-ote\sdq.txt"
Enabled_19=True
ROMName_19=tq
GameName_19=Thayer's Quest
GameOptions_19=-framefile "C:\Roms\Laserdisc\Thayer's Quest q.txt"
Enabled_20=True
ROMName_20=uvt
GameName_20=Us vs Them
GameOptions_20=-framefile "C:\Roms\Laserdisc\Us vs Them\uvt.txt"
UseGamepad=False
DaphneFlyer=C:\Emulators\Daphne\flyers
DaphneCabinet=C:\Emulators\Daphne\cabinets
DaphneTitle=C:\Emulators\Daphne itles
DaphneMarquee=C:\Emulators\Daphne\marquees
DaphnePanel=C:\Emulators\Daphne\cpanel
LaunchBefore=
LaunchAfter=
DaphneCustomGameExtenderCustomArtPath=C:\Emulators\Daphne\marquees
DaphneBakSNAP=C:\Emulators\Daphne\backgroundimages
[DVD]
EnableDVD=True
CODEC=0
DVDFFDSHOW=0
EnableDVDDisk=True
DVDPath=C:\DVD
UseVMR9=True
EnableExternalPlayer=False
Use VMR9=False
CMD=""C:\Program Files (x86)\Corel\DVD9\WinDVD.exe" "[dvd]""
[Pictures]
PicturesEnabled=True
paths=C:\GameEx\DEMO\Pictures;C:\Pictures;[mypictures]
UseAlphaBlend=True
SlideDuration=12
[News]
URL_1=http://rss.news.yahoo.com/rss/topstories
URL_2=
URL_3=http://rss.news.yahoo.com/rss/tech
URL_4=http://slashdot.org/index.rss
URL_5=
URL_6=http://www.emulator-zone.com/rss_news.php
URL_7=http://www.spesoft.com/news.xml
URL_8=http://www.gameex.info/forums/index.php?app=core&module=global&section=rss&type=forums&id=1
URL_9=http://www.hulu.com/feed/highest_rated/videos
URL_10=http://www.hulu.com/feed/popular/videos/this_week
URL_11=http://www.hulu.com/feed/recent/movies
URL_12=
URL_13=
URL_14=
URL_15=
URL_16=
URL_17=
URL_18=
URL_19=
URL_20=
URL_21=
URL_22=
URL_23=
URL_24=
URL_25=
URL_26=
URL_27=
URL_28=
URL_29=
URL_30=
URL_31=
URL_32=
URL_33=
URL_34=
URL_35=
URL_36=
[Radio]
RadioEnabled=True
Enabled_5=True
Name_5=Kohina - old school game & demo
URL_5=http://acamar.org:8000/listen.pls
Enabled_6=False
Name_6=Bangkok Radio
URL_6=http://64.62.253.55/bangkok64
Enabled_7=True
Name_7=Kohina - Fresh Tracks
URL_7=http://anka.org:8080/fresh.ogg.m3u
Enabled_4=False
Name_4=Delta Uno
URL_4=http://www.deltauno.it/home/delta1.asx
Enabled_1=False
Name_1=
URL_1=
Enabled_2=
Name_2=
URL_2=
Enabled_3=
Name_3=
URL_3=
Enabled_8=
Name_8=
URL_8=
Enabled_9=
Name_9=
URL_9=
Enabled_10=
Name_10=
URL_10=
Enabled_11=
Name_11=
URL_11=
Enabled_12=
Name_12=
URL_12=
Enabled_13=
Name_13=
URL_13=
Enabled_14=
Name_14=
URL_14=
Enabled_15=
Name_15=
URL_15=
Enabled_16=
Name_16=
URL_16=
Enabled_17=
Name_17=
URL_17=
Enabled_18=
Name_18=
URL_18=
Enabled_19=
Name_19=
URL_19=
Enabled_20=
Name_20=
URL_20=
Enabled_21=False
Name_21=Capital Gold
URL_21=mms://ms1.capitalinteractive.co.uk/gold_high
Enabled_22=True
Name_22=Slay Radio
URL_22=
http://relay4.slayradio.org:8000
Name_23=XFM
URL_23=http://rope.icgo.fimc.net/staticweb/onair_players/onair_xfm_abacast/player/onair_xfm.asx
Enabled_23=False
Name_24=Radio Woodstock
URL_24=http://nick8.surfernetwork.com/Media/RWST.asx
Enabled_25=True
Name_25=Club 977 Alternative
URL_25=http://www.977alt.com/977alt.asx
Enabled_26=True
Name_26=Radio Paradise
URL_26=http://www.changeip.com/radio/rp_128.asx
Enabled_27=True
Name_27=Hitz Radio
URL_27=http://www.hitzradio.com/hitzradio.asx
Enabled_28=True
Name_28=Club 977
URL_28=http://www.club977.com/club977.asx
Enabled_29=True
Name_29=9412 Rock Station
URL_29=http://www.9412.com/9412.asx
Enabled_30=True
Name_30=Power Hitz
URL_30=http://www.powerhitz.com/powerhitz.asx
Enabled_31=True
Name_31=Radio Wazee
URL_31=http://www.wazee.org/128.asx
Enabled_32=True
Name_32=The Edge Radio
URL_32=http://mfkrboard.com/edgeradio/edge.m3u
Enabled_33=True
Name_33=WFUV 90.7 FM Public Radio
URL_33=http://www.wfuv.org/wfuvlive.asx
Enabled_34=False
Name_34=Pirate Radio
URL_34=http://www.loudcity.net/Portals/0/LCPlayLists/90/123.asx
Enabled_35=True
Name_35=EYE 97
URL_35=http://www.loudcity.net/Portals/0/LCPlayLists/157/eye97.asx
Enabled_36=True
Name_36=Hit Music Station
URL_36=http://www.hitmusicstation.net/ecoute_haut_debit.m3u
Name_37=Radio IO 80's
URL_37=http://radioio.sc.llnwd.net:8240
Enabled_24=
Enabled_37=False
Enabled_80=True
Url_80=FAVREMOVE
Enabled_81=True
Url_81=FAVREMOVE
Enabled_82=True
Url_82=FAVREMOVE
Enabled_83=True
Url_83=FAVREMOVE
enabled_84=True
name_84=radioio.com : 80s New Wave
url_84=http://www.shoutcast.com/sbin/shoutcast-playlist.pls?rn=1269943&file=filename.pls
Enabled_85=
Name_85=
Url_85=
Enabled_38=True
Name_38=C64.COM's SID Stream
URL_38=http://www.c64.com/sid.m3u
[htmlApplications]
Enabled_1=True
URL_1=http://10foot.cbuenger.com/mceWeather/index.php?start=1〈=2
Name_1=Weather
Logo_1=Weather
MouseEmu_1=False
Enabled_2=True
URL_2=http://gameex.net
Name_2=GameEx homepage
Logo_2=
MouseEmu_2=False
Enabled_3=False
URL_3=http://10foot.cbuenger.com/mceWeather/index.php?start=1〈=2
Name_3=Weather
Logo_3=Weather
MouseEmu_3=True
Enabled_4=False
URL_4=
Name_4=
Logo_4=
MouseEmu_4=True
Enabled_5=False
URL_5=
Name_5=
Logo_5=
MouseEmu_5=True
Enabled_6=False
URL_6=
Name_6=
Logo_6=
MouseEmu_6=True
UseHTMLApps=True
Hide_2=False
Hide_3=
Hide_4=True
Hide_5=
[ExternalApplications]
Enabled_99=True
Name_99=Configuration
Path_99=[apppath]
CMD_99=GameExConfig.exe
Snap_99=GameExText
ShowDesktop_99=True
MapKeys_99=False
WaitBeforeKeys_99=
SendKeys_99=
Enabled_2=False
Name_2=Notepad
Path_2=c:\windows
CMD_2=notepad.exe
Snap_2=GameExText
ShowDesktop_2=True
MapKeys_2=True
WaitBeforeKeys_2=
SendKeys_2=
Enabled_3=False
Name_3=Mad Dog McCree
Path_3=G:\Mad_Dog_mcCree
CMD_3=G:\Mad_Dog_mcCree\mdm.exe
Snap_3=GameExText
ShowDesktop_3=True
MapKeys_3=True
WaitBeforeKeys_3=4000
SendKeys_3=F
Enabled_1=False
name_1=Close And Restart GameEx
path_1=G:\-DATA-\-MY PROJECTS-\GameEx - VB.net\bin
cmd_1=CloseAndRestartGameEx.bat
snap_1=
showdesktop_1=True
mapkeys_1=True
WaitBeforeKeys_1=d
SendKeys_1=
Enabled_4=False
name_4=
path_4=
cmd_4=
snap_4=
showdesktop_4=True
mapkeys_4=True
WaitBeforeKeys_4=
SendKeys_4=
Enabled_5=False
name_5=
path_5=
cmd_5=
snap_5=
showdesktop_5=True
mapkeys_5=True
WaitBeforeKeys_5=
SendKeys_5=
Enabled_6=False
name_6=
path_6=
cmd_6=
snap_6=
showdesktop_6=True
mapkeys_6=True
WaitBeforeKeys_6=
SendKeys_6=
Enabled_7=False
name_7=
path_7=
cmd_7=
snap_7=
showdesktop_7=True
mapkeys_7=True
WaitBeforeKeys_7=
SendKeys_7=
Enabled_8=False
name_8=
path_8=
cmd_8=
snap_8=
showdesktop_8=True
mapkeys_8=True
WaitBeforeKeys_8=
SendKeys_8=
Enabled_9=False
name_9=
path_9=
cmd_9=
snap_9=
showdesktop_9=True
mapkeys_9=True
WaitBeforeKeys_9=
SendKeys_9=
Enabled_10=False
name_10=
path_10=
cmd_10=
snap_10=
showdesktop_10=True
mapkeys_10=True
WaitBeforeKeys_10=
SendKeys_10=
Enabled_11=False
name_11=
path_11=
cmd_11=
snap_11=
showdesktop_11=True
mapkeys_11=True
WaitBeforeKeys_11=
SendKeys_11=
Enabled_12=False
name_12=
path_12=
cmd_12=
snap_12=
showdesktop_12=True
mapkeys_12=True
WaitBeforeKeys_12=
SendKeys_12=
Enabled_13=False
name_13=
path_13=
cmd_13=
snap_13=
showdesktop_13=True
mapkeys_13=True
WaitBeforeKeys_13=
SendKeys_13=
Enabled_14=False
name_14=
path_14=
cmd_14=
snap_14=
showdesktop_14=True
mapkeys_14=True
WaitBeforeKeys_14=
SendKeys_14=
Enabled_15=False
name_15=
path_15=
cmd_15=
snap_15=
showdesktop_15=True
mapkeys_15=True
WaitBeforeKeys_15=
SendKeys_15=
Enabled_16=False
name_16=
path_16=
cmd_16=
snap_16=
showdesktop_16=True
mapkeys_16=True
WaitBeforeKeys_16=
SendKeys_16=
Enabled_17=
name_17=
path_17=
cmd_17=
snap_17=
showdesktop_17=
mapkeys_17=
WaitBeforeKeys_17=
SendKeys_17=
Enabled_18=
name_18=
path_18=
cmd_18=
snap_18=
showdesktop_18=
mapkeys_18=
WaitBeforeKeys_18=
SendKeys_18=
Enabled_19=
name_19=
path_19=
cmd_19=
snap_19=
showdesktop_19=
mapkeys_19=
WaitBeforeKeys_19=
SendKeys_19=
Enabled_20=
name_20=
path_20=
cmd_20=
snap_20=
showdesktop_20=
mapkeys_20=
WaitBeforeKeys_20=
SendKeys_20=
Enabled_21=
name_21=
path_21=
cmd_21=
snap_21=
showdesktop_21=
mapkeys_21=
WaitBeforeKeys_21=
SendKeys_21=
Enabled_22=
name_22=
path_22=
cmd_22=
snap_22=
showdesktop_22=
mapkeys_22=
WaitBeforeKeys_22=
SendKeys_22=
Enabled_24=
name_24=
path_24=
cmd_24=
snap_24=
showdesktop_24=
mapkeys_24=
WaitBeforeKeys_24=
SendKeys_24=
Enabled_25=
name_25=
path_25=
cmd_25=
snap_25=
showdesktop_25=
mapkeys_25=
WaitBeforeKeys_25=
SendKeys_25=
EmulateMouse_1=-1
EmulateMouse_2=-1
EmulateMouse_3=3
EmulateMouse_4=
EmulateMouse_5=
EmulateMouse_6=
EmulateMouse_7=
EmulateMouse_8=
EmulateMouse_9=
EmulateMouse_10=
EmulateMouse_11=
EmulateMouse_12=
EmulateMouse_13=
EmulateMouse_14=
EmulateMouse_15=
EmulateMouse_16=
EmulateMouse_17=
EmulateMouse_18=
EmulateMouse_19=
EmulateMouse_20=
EmulateMouse_21=
EmulateMouse_22=
EmulateMouse_24=
EmulateMouse_25=-1
LaunchBefore_16=
LaunchAfter_16=
AlsoLaunch_16=
LaunchBefore_17=
LaunchAfter_17=
LaunchBefore_1=
HelpText_1=
[TEXT]
steamlist=Steam
steamstart=Steam Games
banner=Banner
Downloading=Downloading
Seeking=Seeking
Download=Download
PlayBluRay=Play Blu Ray
GetMetaData=Get MetaData
Touch_Help_1=Control is located at bottom of screen.
Touch_Help_2=Continuously tap bottom right for credits and top right to start.
Touch_Help_3=Controls are located bottom and middle of screen.
Touch_Help_4=Control is located at bottom of screen.
GameExArcadeStart=Arcade
GameExArcadeList=Arcade
RipDVD=Rip DVD
SearchMusic=Search Music
Dialog_RippingCD=Ripping CD
Dialog_PleaseWait=Please Wait
Dialog_ScanningFolders=Scanning Folders
Dialog_ScanningFiles=Scanning Files
Dialog_LoadingDatabases=Loading Databases
Dialog_LoadingSettings=Loading Settings
Status_ListUpdated=List Updated
Status_FavRemoved=Removed from favorites
Status_FavAdded=Added to favorites
Status_ItemRemoved=Item removed
Status_NextTrack=Next track
Status_PreviousTrack=Previous track
Status_Pause=Pause
Status_play=Play
Status_AddedToQ=Added to queue
Status_NetPlayReq=Requested NetPlay
Status_NetPlayCan=Cancelled NetPlay
YouTube=YouTube
News=News
SearchYouTube=Search YouTube
RequestNetPlay=Request NetPlay
CancelNetPlay=Cancel NetPlay Request
MAMENetPlayStart=MAME NetPlay
NetPlayList=NetPlay
Accept=Accept
Now=Now
Next=Next
GameMusic=Game Music
TVAdvert=TV Advert
Commands=Commands
RecordVideo=Record Video
ResumeGame=Resume Game
ExitGame=Exit Game
InGame=In Game
Stopped=Stopped
Play=Play
ResumeDVD=Resume DVD
NoItems=- NO ITEMS FOUND -
Hibernate=Hibernate
MenuMore=More
AllGamesStart=All Games
AllGamesList=All Games
NotAvailable=Not Available
HiScore=High Score
GetLyrics=Get Lyrics
OtherSystems=Other Systems
OpenMedia=Open Media
Biography=Biography
MenuView=Change View
MenuBack=Back
MenuExit=Exit
MenuHome=Home
LastPlayedList=Last Played
LastPlayedStart=Last Played
SEARCHTITLE=Enter criteria then select menu
SEARCHTITLE2=Press select to release cursor
SearchList=Search
SearchStart=Search
SearchMedia=Search Media
SearchJukebox=Search Jukebox
Items=Items
MediaPlayerStart=Library
MediaPlayerList=Library
NoMediaFound=- NO MEDIA FOUND -
eBookViewerStart=eBooks
eBookViewerList=eBooks
Artwork=Artwork
PCB=PCB
Statistics=Statistics
InsertCD=Insert CD:
SearchGames=Search Games
GameManual=Manual
PlayStation=Playstation
mame2simlist=2 Players
mame2simstart=2 Player Simultaneous
mame4simlist=4 Players
mame4simstart=4 Player Simultaneous
MCEEXPORT=Export To MCE
StartScreenSaver=Start Screensaver
Visualize=Visualize
SelectVisualize=Select Visualization
About1=Windows Emulator Front End and HTPC
About2=Written By:
About3=For Latest Version, please visit:
byalbum=By Album
byartistalbum=By Artist/Album
byartist=By Artist
bycat=By Category
bygenre=By Genre
bymanu=By Manufacturer
bysys=By System
byname=By Name
bytitle=By Title
byyear=By Year
Selectplaylist=Play list / More
createsnaps=Create Snaps
CreateSnaps1A=You are about to create snap shots or videos for every game in the [EMULATOR] Games List. This option can be removed from GameEx, by enabling the Hide Create Snaps option in the configuration.
CreateSnaps2=You should be aware this is a lengthy process
CreateSnaps3=With your current settings it is estimated that it will take at least:
CreateSnaps4=[MINUTES] Minutes to complete this process if you use a 20 second pause between snaps.
CreateSnaps5=You should also be warned that the SNAP shots will be saved in the SNAP Path defined for this emulator
CreateSnaps6=This process is not recommended on Windows 98
CreateSnaps7=To exit this process once run HOLD down ESCAPE.
CreateSnaps8=Do you want to proceed?
Exit=Exit GameEx
HTMLPleaseWait=Please Wait
IsUpdatingList=GameEx is updating the MAME game list:
jukelist=Jukebox
jukestart=Jukebox
Karaokelist=Karaoke
Karaokestart=Karaoke
StartKaraoke=Start Karaoke Player
LaaunchingGame=Launching:
laserlist=Laserdisc
laserstart=Laserdisc Games
logoff=Log Off
favlist=Favorites
favstart=Favorites
mamealllist=MAME Games
mameallstart=All MAME Games
mamecpslist=CPS Games
mamecpsstart=CPS Games
mameAtarilist=Atari Games
mameAtaristart=Atari Games
mameGunlist=Lightgun
mameGunstart=Lightgun Games
mameTrackballlist=Trackball
mameTrackballstart=Trackball Games
mameSpinnerlist=Spinner
mameSpinnerstart=Spinner Games
mameModel2list=Model 2
mameModel2start=Sega Model 2 Games
mameGoldenlist=Golden Era
mameGoldenstart=Golden Era Of Arcade
mameneolist=Neo-Geo
mameNEostart=Neo-Geo Games
mamemultilist=MAME Multiplay
mamemultistart=MAME Multiplayer Games
mamevectorlist=MAME Vector
mamevectorstart=MAME Vector Games
Of=of
shutdown=Turn Off System
standby=Stand By System
Restart=Restart System
Start=Start..
updatelist=Update List
UpdatingList=Updating Game List:
UpdatingPleaseWait=Please Wait......
videoslist=Videos
videostart=Videos
LaunchingGame=Launching Game:
PlayThisGame=Play This Game
Recommended=Recommended Games:
Series=Games in Series:
Title=Title
Flyer=Flyer
Cabinet=Cabinet
Cabinet3d=3D Cabinet
Panel=Panel
Box=Box
Cartridge=Cartridge
Marquee=Marquee
FavoritesAdd=Add To Favorites
FavoritesRemove=Remove From Favorites
NoVideosFound=- NO VIDEOS FOUND -
NoPicturesFound=- NO PICTURES FOUND -
NoMusicFound=- NO MUSIC FOUND -
NoArtistsFound=- NO ARTISTS FOUND -
NoAlbumsFound=- NO ALBUMS FOUND -
NoGenresFound=- NO GENRES FOUND -
NoGamesFound=- NO GAMES FOUND -
NoStationsFound=- NO STATIONS FOUND -
NoNewsFound=- NO NEWS FOUND -
CannotCreateSnaps1=Cannot Create Snaps
CannotCreateSnaps2=Emulator '[EMULATOR]' Does not have a valid Snap path, so Snaps cannot be created. Setup a valid snap path in the configuration and try again.
ViewControls=View Controls
Instructions=Instructions
ViewControlsKey=Press '[KEY]' to view in game.
AllMusic=All Music
ClearCurrentPlaylist=Clear Current Playlist
ShufflePlaylist=Shuffle Current Playlist
PlayLastGame=Last MAME Game
ViewSlideShow=View Slide Show
Pictures=Pictures
Radio=Radio
PlayDVD=Play DVD
PlayCD=Play CD
DVDonDiskStart=DVDs
DVDonDiskList=DVDs
Demo=Demo:
Playing=Playing:
MAMEOriginal=MAME Original Games
MAMEOriginallist=Originals
MAMEAdult=MAME Adult Games
MAMEAdultlist=Adult
ClearAndQueueAll=Clear and Queue All
AddAndQueueAll=Add all to Queue
RandomGame=Play Random Game
StartMAME=MAME
StartApps=More Games & Programs
StartEMU=Emulated Games
StartControl=Exit/Shutdown
StartMedia=Multimedia
ListMAME=MAME
ListApps=Games & Apps
ListEMU=Games
ListControl=Exit
ListMedia=Media
TimesPlayed=Times Played
LastPlayed=Last Played
DeleteFavs=Delete Favorites
DeleteMost=Delete Most Played
Chapter=Chapter
Aspect=Aspect
Aspect0=Original Aspect - Not Zoomed
Aspect4=Widescreen on 4:3 - Stretched
Aspect5=Fill Screen
Aspect3a=Widescreen to 4:3 - Zoomed
Aspect3b=Letterbox to Widescreen - Zoomed
Aspect2=Original Aspect - Zoomed
Aspect1a=Widescreen to 4:3 - Shrunk
Aspect1b=4:3 to Widescreen - Stretched
Paused=Paused
PlayVideo=Play Video
ResumeVideo=Resume Video
RestartVideo=Restart Video
VideoQueue=Play All
QueueAllRandom=Play Randomly
More=More..
MostPlayed=Most Played
MostPlayedList=Most Played
VariousArtists=Various Artists
ConfirmDialog1=Select To Confirm.
ConfirmDialog2=Back To Cancel.
RemoveGame=Remove Game?
LocalDisk=Local Disk
SystemDisk=System Disk
CDDVD=CD/DVD Drive
NetworkDrive=Network Drive
RamDisk=Ram Disk
FloppyDisk=Floppy Disk
RemovableDisk=Removable Disk
UpdateGameList=Update List?
VideoQueueAll=
playstationstart=Playstation
themepickerlist=Themes
themepickerstart=Theme Picker
playstationlist=Playstation
mameVertList=Vertical
mameVertStart=MAME Vertical Games
mameHorizlist=Horizontal
mameHorizstart=MAME Horizontal Games
mamenotplayedlist=Not Played
mamenotplayedstart=MAME Not Played
mamemawslist=Live - MAWS
mameMAWSstart=Live - MAWS Hall Of Fame
mameGameExlist=Live - GameEx
mameGamEexstart=Live - GameEx Favorites
ripcd=Rip CD
ripthiscd=Rip This CD Now
cantrip=- No CD, Invalid CD, or no CDDB data -
ViewPlaylist=View Playlist
KaraokAllSongs=All Songs
KaraokaMode1Click=Instant Play Mode
KaraokaModeQueue=Queue Mode
KaraokePlaylist=View/Edit Playlist
KaraokeStartMenu=Start Karaoke
mammodel2list=
CreateSnaps1=You are about to create snap shots for every game in the [EMULATOR] Games List.
NoeBooksFound=- NO EBOOKS FOUND -
QueueAll=Queue All
[Favorites]
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
[DVRMS]
DVRFFDSHOW=0
CODEC=
[AtractModeNewGameTimer]
When in attract mode start a new random game or video each time this value is reached.=2
[AttractVideosPath]
The folder your videos are located.=L:\GameAds
[GameExTender]
RemoteGameExLocation=\\workstation1\g$\-DATA-\-MY PROJECTS-\GameEx - VB.net\bin
Enabled=False
Windowed=False
RemoteExtenderLocation=G:\-DATA-\-MY PROJECTS-\GameEx - VB.net\bin
IPADDRESS=127.0.0.1
Port=8383
RefreshRate=20
SysUserName=Arcade
Username=User33549
ComputerName=ARCADE-PC
Publish=False
UserInfo=
GameExtenderCustomImage=False
GameExtenderImageNotFound=
[GameExtenderViewer]
Server=90.0.0.13
PORT=8383
RefreshRate=7
StartWithGameEx=False
ExitWithGameEx=False
Windowed=False
[Karaoke]
Enabled=False
Path=C:\Karaoke
mode=False
[CachedImages]
bak=100652
res=786432
videobak=100652
jukeboxbak=100652
radiobak=100652
picturesbak=100652
emubak=100652
startbak=100652
daphnebak=100652
mamebak=100652
themedir=
titlefont=Trebuchet MS
titlefontsize=0
outlinefonts=False
antialiasfonts=True
windowed=True
use16bitcolour=False
gradienttitlefont=True
lowercasetitlefont=True
Font=Trebuchet MS
FontSize=0
titlefontres=275808
bakres=786432
theme=
startbak_Foreground=386810
videobak_Foreground=386810
jukeboxbak_Foreground=386810
radiobak_Foreground=386810
picturesbak_Foreground=386810
daphnebak_Foreground=386810
titlefontstyle=0
bakresbak=921600
mameselectbak=465213
lastplayedbak=290516
mostplayedbak=199198
favoritesbak=283065
allgamesbak=375154
emulatorselectbak=100444
themepickerbak=621253
[Plugin_1]
Enabled=False
Name=CursorHider.dll
[Plugin_2]
Enabled=False
Name=Game Info Plugin.dll
[Plugin_3]
Enabled=False
Name=PlugInCallerID.dll
[Plugin_4]
Enabled=False
Name=PlugInDigDug.dll
[Plugin_5]
Enabled=False
Name=PlugInExit.dll
[ArcadeSoundPlugin]
Volume=8
[Plugin_6]
Enabled=False
Name=PlugInLaunch.dll
[CachedImagesMenuFont]
themedir= hemes\Default - RedEx - MCE1024x768\MEDIA\
res=786432
font=Trebuchet MS
fontsize=0
outlinefonts=False
antialiasfonts=True
windowed=False
menufontsamesize=False
fontstyle=1
[CachedImagesBak]
bak=214295
videobak=214295
jukeboxbak=214295
radiobak=214295
picturesbak=214295
emubak=214295
startbak=214295
daphnebak=214295
[Emulator_]
SelectionMusicFolder=C:\Music
[eBook]
Paths=C:\eBooks
Quality=0
fittopage=False
[Plugin_7]
Name=PlugInLCD.dll
[MediaPlayer]
AudioMode=0
[CachedImagesGameFont]
res=786432
[CachedImagesGameFontFaded]
res=786432
[CachedImagesFontBlack]
Res=277056
[CPWizard]
CPWizardEnable=False
CPWizardPath=C:\Program Files\CPWizard\CPWizard.exe
CPWizardStarted=True
CPWizardStartup=True
UseWMPWMV=
CMD=
[ADVKEYBOARD]
Forward=60
Rewind=61
PageUp=62
PageDown=63
VolumeDown=64
VolumeUp=65
Stop=66
Play=67
[Plugin_8]
Enabled=False
Name=PlugInRotate.dll
[CursorHider]
DoNotHide=
DoNotHideInGameEX=False
[Plugin_9]
Enabled=False
Name=PlugInSpeech.dll
[DefaultPaths]
EmuPath1=C:\Emulators
AssetPath1=C:\Assets
RomPath1=C:\Roms
[GameBase]
Enabled=False
Path=
MapBack=False
ShowDesktop=True
[CachedImages3d]
titlefontres=786432
titlefontstyle=0
titlefontsize=0
outlinefonts=False
gradienttitlefont=False
lowercasetitlefont=False
antialiasfonts=True
windowed=False
res=0
bakres=0
startbak_foreground=386810
theme=BlueBox
bak_foreground=39023
jukeboxbak_foreground=23206
[CachedImagesGameFontFadedFalse]
res=921600
[CachedImagesMenuFont3d]
res=0
[DVDRIP]
Format=MP4
DVDRIPFOLDER=C:\DVD RIPS
Profile=Normal
CUSTOMCMD=
[GameExArcade]
[Touchscreen]
Touchscreen_Enabled=2
Touchscreen_HidePointer=True
TouchScreen_ShowHelpScreens=True
TouchScreen_SingleClick=True
TouchScreen_OnlyCompatibleGames=True
TouchScreen_CheckForExit=True
TouchScreen_SendCredit=True
TouchScreen_ShowMouseAnimations=True
[LastStatus]
specialfilter=
oldspecialfilter=
curemulator=0
listtype=0
curbak=bak
maxgames=2832
gamename=
[Plugin_10]
Enabled=False
Name=PlugInUltraStik.dll
[Plugin_11]
Enabled=False
Name=RandomArcadeSound.dll
[list_SETTINGS_20_EMU_1002]
displaybackgroundimage=True
displaybackgroundimageemu=False
displaystartpagemenuimage=False
displaystartpagemenuimage2=False
displaystartpagelistnotforcebaksnap=True
displayimagelist=False
[list_SETTINGS_20_EMU_503]
displaybackgroundimage=Snap
displaystartpagelistnotforcebaksnap=False
displayimagelist=True
[steam]
LaunchBefore=
LaunchAfter=
[iNTERNAL]
currentstation=
VGenre=---
OPTIMIZED=0
version=12.85
timesruncount=9
ambiancefolderlistposition=1
startpagethumbscount=3
lastglaunchlist=0
glaunchlistselected_0=1
glaunchlisttop_0=1
viewalbumtype=0
windowed=False
selectedgame=1
gamelisttop=1
catfilter=
manufilter=
yearfilter=
listtype=0
emulator=0
yearlisttop=1
catlisttop=1
namelisttop=1
manulisttop=1
yearselectedgame=1
catselectedgame=1
manuselectedgame=1
nameselectedgame=1
romname=mk2
romname2=mk2
specialfilter=
currentstationurl=
mamevideolists_reset18_mamef=False
mamevideolists_lastmodified_mamef=8/16/2010 11:32:17 AM
mamevideolists_lastmodifiedlist_mamef=7/24/2010 2:06:58 PM
emu_1lastfolderwrite=8/16/2010 11:32:17 AM
emu_1lastromfilter=*.avi
emu_1_dbcachemodified=7/10/2012 1:28:28 PM
emu_1_lastnumgames=4
emu_1_dbcachelastname=[Console] Atari 5200
emu_1_dbcacheinicreated47=True
emu_2lastfolderwrite=8/16/2010 11:32:17 AM
emu_2lastromfilter=*.avi
emu_2_dbcachemodified=7/10/2012 1:29:34 PM
emu_2_lastnumgames=4
emu_2_dbcachelastname=[Console] Nintendo SNES
emu_2_dbcacheinicreated47=True
emu_3lastfolderwrite=8/16/2010 11:32:17 AM
emu_3lastromfilter=*.avi
emu_3_dbcachemodified=7/10/2012 1:29:12 PM
emu_3_lastnumgames=4
emu_3_dbcachelastname=[Console] Nintendo N64
emu_3_dbcacheinicreated47=True
mamevideolists_list_mamef=
windowx=0
windowy=0
windowwidth=640
windowheight=480
mameexe=mame.exe
mamefilemodified=2/5/2012 4:24:32 PM
mamefilesize=104990442
mamepromptupdate=False
mameis32bit=True
bezelversion=3
mameversion=0.145
lasticonpath=E:\emu\MameUI32\icons
[Emulator_1]
CustomArtPath3=
CustomArtName3=
CustomArtPath2=
CustomArtName2=
CustomArtPath1=
CustomArtName1=
CDCheckFile=
CDCheck=
RandomMostPlayed=
ShowMostPlayed=
PlayInScreenSaver=
MergeSets=
GamesIn7Zips=
UseDbName=
PCGame=
PlaySelectionMusic=
DontShowInfo=
PlayMusic=
CustomBackground=
ExcludedFiles=
LaunchAfter=
LaunchBefore=
AlsoLaunch=
Debug=
ShowDesktop=
RemoveBrackets=
Capitals=
ReplaceUnder=
ReplaceDash=
SendKeys=
WaitBeforeKeys=
MapKeys=
WorkingPath=C:\Users\Arcade\Desktop\New Folder (2)\MAME
ControlPanelPath=C:\Users\Arcade\Desktop\New Folder (2)\MAME\Controls
ManualPath=C:\Users\Arcade\Desktop\New Folder (2)\MAME\Manuals
CartPath=C:\Users\Arcade\Desktop\New Folder (2)\MAME\Cartridges
BoxPath=C:\Users\Arcade\Desktop\New Folder (2)\MAME\Boxes
TitlePath=C:\Users\Arcade\Desktop\New Folder (2)\MAME\Titles
SnapPath=C:\Users\Arcade\Desktop\New Folder (2)\MAME\Snaps
RomPath=C:\Users\Arcade\Desktop\New Folder (2)\MAME\Roms
MapFile=[APP]\Map Files\[Arcade] MAME.map
ConfigFile=[Mapping Off] Exit (Process Close)
Database=
RomFilter=
Command=mame.exe [ROM] -rompath "[ROMPATH]"
StartPageLogo=MAME
StartPageName=[Arcade] Arcade (MAME)
TitleText=Mame
Info=MAME stands for Multiple Arcade Machine Emulator. When used in conjunction with images of the original arcade game's ROM and disk data, MAME attempts to reproduce that game as faithfully as possible on a more modern general-purpose computer. MAME can currently emulate several thousand different classic arcade video games from the late 1970s through the modern era.
Website=http://mamedev.org/
RequiredFiles=
DownloadUrl=http://www.gamesdbase.com/setupwizard/emulators/download/mame.7z
Rating=8.4
Version=0.145
Emulator=MAME
Category=Arcade
System=Arcade
[Emulator_2]
[Emulator_3]
[setupWizard]
EmuPath1=C:\Users\Arcade\Desktop\New Folder (2)
AssetPath1=C:\Users\Arcade\Desktop\New Folder (2)
RomPath1=C:\Users\Arcade\Desktop\New Folder (2)
DefaultPathPrompt=True
DownloadDatabasePrompt=True
DownloadEmulatorPrompt=True
WizardMode=1
CustomArray=
SearchArray=
SavePosition=False
SectionIndex=37
SearchText=
EmulatorIndex=0
EmulatorGroupIndex=0
DaphneIndex=0
HTMLAppsIndex=0
ExternalAppsIndex=0
RadioStationsIndex=0
NewsFeedsIndex=0
ShowPanel=True
FontSize=1
WindowState=0
WindowSize=650,478
WindowLocation=174,20
[Plugin_12]
Enabled=False
Name=Xpadder Plugin.dll
[Emulator_4]
[Emulator_5]
Enabled=False
[Emulator_6]
Enabled=False
[Emulator_7]
Enabled=False
[Emulator_8]
Enabled=False
[Emulator_9]
Enabled=False
[Emulator_10]
Enabled=False
[Emulator_11]
Enabled=False
If you would post a pic of each Tab in the LCD Plugin, your mame.ini, and a description of the hardware that drives the LEDs, (Pacdrive, LEDwiz, etc...) I will try to help you.
