Hey,
From the look of your attached snaps, the way to do it is to open up theme editor and move the date and time to an area where they are not in the way.
If you are unable to do this, please come back here and let us know.
Since it is a Version 1 theme, you will have to create a new theme using that theme as the source. It appears you are using a resolution that is not the native resolution of the theme (1920x1200 vs the theme's 1024x768, thus distorting the image and item layouts by translating a 4:9 aspect ratio to 16:10). Once you load the theme, as KRC noted, you will need to move the items to fit within the converted theme.
with a older version of gameex like 11.79 works that heme fine and without a problem if i use 1920x1200 or 1920x 1080 , i dont know wy now dont work
To be honest, I am not sure why it didn't manifest the display issue you encounter now previously. This is not a bug or error if it is doing so now.
If you are using a theme to display in an aspect ratio for which it was not designed, then the images will distort and theme elements locations on the screen will be skewed as a result.
If you feel that this judgement is incorrect, please provide copies of your log.txt and gameex.ini file. Otherwise, please try the suggested fixes and report back if they resolve the problem for you -or- select one of the other themes that are more in line with your desired display.
Hi Tom,
here the log and gameex ini.
i change the font size to bigger and now it work fine....
but its for me to big and on normal size... i can the problem reproduce :(
please can you take a look ? i build my htpc with gameex and i will finish this soon :)
GameEx.ini
