I have done everything that I know to do to make the extender viewer show up on my 2nd display.
I have a HDTV that I use to play my games and I have a 19 inch Flat screen on my coffeetable. In the new section of the Configurator, I have tried both settings that pertain to the extender being on the 2nd display (Yes and No)
I have also tried the Nvidia proggie that allows one to select an executable and force it in a certain display. This didn't work either.
I know that the extender is working because when I exit out of GameEx there is some pictures on the extender. Of course, the problem is that they are opening up on the same display.
I probably should build a 2nd computer, but I would like it to display on my monitor on my coffetable instead.
Thanks for the excellent work, Tom. Really amazing coding. I wish you could see the setup here at the house. You would be proud. :)
Thanks for reporting this is fixed in GameEx 5.38 now available.
I'd love to see your setup, can you post some pics?
