Hit a small snag with the setup wiz.with the old advanced config utility you used to be able to set separate paths for mameinfo.dat,catver.ini,controls.dat,command.dat & history.dat reason being is every time GameEX updates it overwrites the newer files I put there with older versions.well you cannot do this with the setup wizard,well if you can I dont see how but it is kind of important if you update with the "u" releases like I do.Hopefully this can be fixed? :)
Well spotted dave, hadnt noticed that one. Im sure they'll be on it ASAP :)
I would just change the file properties on those to 'read only' if you want a temporary workaround. This also ensures it only updates when you want it to be updated.
GameEx will skip the file if it can't overwrite it AFAIK.
That will do for me. Nice one m8 :)
